Can someone help me with automatic tranny flush/refill
Old Jan 21, 2004 | 06:24 PM
=GAME='s Avatar
Default Can someone help me with automatic tranny flush/refill
whats up. i dont browse thru this forum much since i be in the EG forum but my question is How would i go about changing a 2000 accord v6 auto transmission fluid. I tried searching but couldnt find what i was looking for. Is it anything similiar to 4 cyclinder motors? Im dont know much about this v6 motor so if anyone could help or give me a link, it would be much appreciated. tia
Old Jan 21, 2004 | 06:57 PM
the DR.'s Avatar
Default Re: Can someone help me with automatic tranny flush/refill (O.G triple O.G)
If i remeber correctly, there is a 17mm plug on top of the trans, should be visible, drain it through the 3/8" drive plug on bottom, then fill approx 2 quarts through the 17mm plug on top
Old Jan 21, 2004 | 11:41 PM
Stripped Honda's Avatar
99-0104
Default Re: Can someone help me with automatic tranny flush/refill (the DR.)
it is the same as 4 cyl hondas but the tranny is on the other side.... the tranny uses 2.75 quarts of fluid use only honda atf because that tranny is the biggest piece of **** honda has ever built
slatermvp
Apr 13, 2012 04:17 PM
AR-cb7
Apr 8, 2008 09:27 AM
HS2G
Oct 11, 2006 07:36 AM
Poopie
Nov 24, 2004 06:47 AM
ShockerLude89
May 17, 2004 05:18 PM
