Can I fix this?
Old Aug 18, 2004 | 07:16 PM
danmoore80's Avatar
Default Can I fix this?
I have a leak in the hose connected to the power stearing pump. Can someone tell me what part this is. Will I have to take it in to be worked on, or is this something I can do myself. This link will take you to the picture of the problem. The yellow dot is directly where the leak is.
Any help would be greatly appriciated. Thank you in advance.
http://www.clubhotrod.com/phot...=3461
Old Aug 18, 2004 | 08:03 PM
Whitfield Inc.'s Avatar
Default Re: Can I fix this? (danmoore80)
Look's like it's in a piece of the rubber line and since that is high pressure it should be replaced. I have heard of hose companies that have the tool that can swedge ??? a new hose in the old ones place you should check your aera. I So Cal we have a place called G & J and Hose man that can do it for us.
Good Luck
Old Aug 19, 2004 | 07:54 PM
taz77's Avatar
New User
replace it.
Old Aug 19, 2004 | 08:21 PM
FlipSkater
Guest
Posts: n/a
Default Re: Can I fix this? (taz77)
wtf are you doing on hot rod site with a honda
Old Aug 24, 2004 | 09:54 PM
danmoore80's Avatar
I have a 1969 firebird as well, so I post there often
HndaOwner
Mar 8, 2016 04:14 PM
Solidis
Sep 13, 2013 11:29 AM
greasemonkee
Welding / Fabrication
13
Jun 21, 2008 11:10 PM
