Why Rebuild Engine?
Old Aug 24, 2004 | 01:09 PM
JDM00SI's Avatar
Default Why Rebuild Engine?
sup,
What would be some of the benefits of rebuilding your engine other than more reliabliity and faster? How much more hp would you gain doing this? Thanks
Old Aug 24, 2004 | 07:18 PM
JDM00SI's Avatar
Default Re: Why Rebuild Engine? (bigbeasta4)
bump
Old Aug 24, 2004 | 07:29 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbeasta4 &raquo;</TD></TR><TR><TD CLASS="quote">How much more hp would you gain doing this?</TD></TR></TABLE>
If the motor is stock and you use all oem parts, you should be at the stock hp rating once again.
what's your plans for the rebuild?
Old Aug 24, 2004 | 10:47 PM
murtnabila's Avatar
Default Re: Why Rebuild Engine? (eda6 hb)
-You can rebuild to be stock. Basically like a new motor so should be reliable compared to one with 250k miles.
-You can build to be STRONGER and still stock hp ratings. Will be able to handle more boost and nitrous than stock.
-You can build to be STRONGER and be less than stock hp settings. Mostly always used for turbo motors or some with high shots of nitrous use.
-you can build to be STRONGER and have some to lots of hp gains
I'm sure theirs more, but I hope you understand.
undeniabl3niguh
Jan 31, 2006 04:38 PM
PreludeK
Jun 8, 2003 06:23 PM
Spaceballsthelunchbox
Dec 11, 2002 04:37 PM
crxgurlllll
Mar 5, 2002 11:06 AM
