can this be done ?
Old Dec 3, 2004 | 03:33 PM
B18C5NA's Avatar
Default can this be done ? pics at bottem
i have a b18c5 sleeved block to 85mm , i hydrolocked it , and threw a rod(crower) threw the bottem of the first cylinder under the sleeve. the bottem of the cylinder has a little notch from where the rod broke in half ,now my question is if i weld the dime size hole and replace the rods with new ones and leave the bottem of the sleeve alone will this work ? what would happen if i put it back together but left the lil notch ?thanks
Modified by B18C5NA at 11:47 AM 12/4/2004
Old Dec 3, 2004 | 03:35 PM
B18C5NA's Avatar
Default Re: can this be done ? (B18C5NA)
oh and if someone can tell me how to post pics i will ... thanks
Old Dec 3, 2004 | 03:44 PM
PrettyLude's Avatar
you can't just say replace rods with new ones, you have to have someone look at the journals to see if they are ok
Old Dec 3, 2004 | 05:12 PM
B18C5NA's Avatar
Default Re: (PrettyLude)
i need new rods -ones bent and the other one is in 2 parts
Old Dec 3, 2004 | 05:38 PM
Kamin's Avatar
Default Re: (B18C5NA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5NA &raquo;</TD></TR><TR><TD CLASS="quote">i need new rods -ones bent and the other one is in 2 parts</TD></TR></TABLE>
you cant just put rods in an engine you just destrioed, the entire thing needs to be measured to see if its even usable.
Old Dec 3, 2004 | 05:48 PM
B18C5NA's Avatar
Default Re: (Kamin)
i know this ,im saying after it gets dingleberry honed and hot tanked and after its been sonic checked ,and mesured up with pistons.. plus if i knew how i would post pics ..
Modified by B18C5NA at 7:53 PM 12/3/2004
Old Dec 4, 2004 | 08:28 AM
B18C5NA's Avatar
Modified by B18C5NA at 11:41 AM 12/4/2004
Old Dec 4, 2004 | 10:45 AM
B18C5NA's Avatar
Old Dec 5, 2004 | 12:26 AM
PrettyLude's Avatar
dang that doesn't look good at all
Old Dec 5, 2004 | 12:28 AM
gaydm.accord's Avatar
no oil leaking outside the block?
Old Dec 5, 2004 | 12:50 AM
B18C5NA's Avatar
Default Re: (gaydm.accord)
no oil leaks or coolent mix
Old Dec 5, 2004 | 03:01 PM
B18C5NA's Avatar
can anybody answer my question?
Old Dec 5, 2004 | 04:41 PM
Dammit_Dan_954's Avatar
Default Re: can this be done ? pics at bottem (B18C5NA)
I'm no expert, but I would check for roundness and make sure the sleeve didn't shift at all. As long it it didn't u should be fine, since the piston does not travel down that far.
Just my opinion.
Old Dec 5, 2004 | 04:56 PM
B18C5NA's Avatar
Default Re: can this be done ? pics at bottem (FastAssEG)
so after i get it all inspected and cleaned up ect.. and just say it checks out ,and put it all back together will it burn oil from those notches on the bottem ? thanks
Old Dec 5, 2004 | 05:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5NA &raquo;</TD></TR><TR><TD CLASS="quote">so after i get it all inspected and cleaned up ect.. and just say it checks out ,and put it all back together will it burn oil from those notches on the bottem ? thanks </TD></TR></TABLE>
As long as it doesn't affect the piston rings u should be fine. Why don't u check ith your locla builder or machine shop.
Old Dec 5, 2004 | 05:31 PM
B18C5NA's Avatar
im just trying to get info before i waste time and money bringing it places, trying to save my self the headaches , thanks .
Old Dec 6, 2004 | 09:50 AM
B18C5NA's Avatar
up
Old Dec 6, 2004 | 06:56 PM
B18C5NA's Avatar
bump
Old Dec 7, 2004 | 04:54 PM
B18C5NA's Avatar
bump bump
Old Dec 7, 2004 | 06:32 PM
legends's Avatar
I don't really know that much about welding blocks, but from what I know about welding, I wouldn't trust the weld. But, make sure you take it to a good welder.
Old Dec 8, 2004 | 05:36 AM
B18C5NA's Avatar
Default Re: can this be done ? pics at bottem (legends)
ive spoken to 2 machine shops (on the phone)and both said it can be welded .
Old Dec 8, 2004 | 07:05 AM
B18C5NA's Avatar
bump
Old Dec 8, 2004 | 09:41 AM
BoostedJeff's Avatar
heh, i would find a new block. that block isnt very promising
Old Dec 8, 2004 | 09:53 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: can this be done ? pics at bottem (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">heh, i would find a new block. that block isnt very promising</TD></TR></TABLE>
Old Dec 8, 2004 | 11:04 AM
B18C5NA's Avatar
Default Re: can this be done ? pics at bottem (LSVTEC 91 Civic)
so this block is junk then ? whata waste is it worth anything?
