cams for SOHC
Old Sep 26, 2004 | 03:50 PM
tunerhonda99's Avatar
Default cams for SOHC
i was wonderin, i have a question... i know if i put on a aftermarket cam gear it wont do much, but if i put in a new camshaft will it help any??
-jordan
Old Sep 26, 2004 | 05:44 PM
1point5CRX's Avatar
Default Re: cams for SOHC (tunerhonda99)
an aftermarket cam will make power but im actually running my stock zc cam with a camgear and dropped .3 off my times.
Old Sep 27, 2004 | 09:00 AM
EX-T's Avatar
Default Re: cams for SOHC (1point5CRX)
You have 1 cam so it's singular.
If you upgrade to an aftermarket cam you will sacrifice power in different places to gain in others.
IMO Zex/Comp has one of the best SOHC cams out there.
Old Sep 29, 2004 | 05:26 PM
lohatch's Avatar
what motor do you have??? Y8??
Old Sep 29, 2004 | 07:23 PM
ViZ's Avatar
ViZ
Default Re: cams for SOHC (lohatch)
gude makes pretty good cams for SOHC, not the best for DOHC though
and you will still see a good gain for the money, not much though with the cam gear unless your doing alot more mods and then the tuning will help
Old Sep 30, 2004 | 03:56 AM
civic-4-ges's Avatar
Default Re: cams for SOHC (ViZ)
Crower stage 1 or 2's are great for sohc vtec!
Old Sep 30, 2004 | 07:08 AM
mycrxsi's Avatar
if your running turbo then the stock cam will be the best, on turbo you want the least amount of overlap you can get. gude,zex,webcams, all make good cams for your motor.
SpoonKid
Aug 23, 2005 08:31 PM
mixmastabob
Nov 10, 2004 07:43 PM
ShiroX
23
Jul 12, 2004 05:49 PM
djsgtrip
10
Aug 14, 2003 12:22 AM
SiRSoL
Feb 25, 2002 08:29 AM
