Camber question
Old Oct 31, 2003 | 05:08 AM
B00stedCoupe's Avatar
Default Camber question
I have a 94 ex and I bought cheap ebay coil overs. with tokico illuminas. well after installation I had just a bit of nevative camber on the front wheels. well the ride quality was bad so I now have eibach prokit. but do I need to get a camber correction kit before I install it or will the springs reverse the camber? to my understanding the drop isnt that low with the prokit and If I had used it before I wouldnt have the negative camber.
Old Oct 31, 2003 | 05:11 AM
mycivicstoo(s)low's Avatar
Default Re: Camber question (B00stedCoupe)
You probably won't suffer any lasting effects from the coilovers, but get an alignment anyway. The prokit lowers enough that you should get your toe fixed. Camber may not be a problem for you.
Old Oct 31, 2003 | 06:17 AM
Default Re: Camber question (mycivicstoo(s)low)
U mean an alignment kit or just a chassis aliginment?
Old Oct 31, 2003 | 06:28 AM
SleepyEG's Avatar
camber isn't adjustable on your car...Your best bet is to put the springs on, and see how the camber is, with the Prokits, it shouldn't be too bad, but if your worried about tire wear, buy yourself some camber kits...
what I've never understood about doing that is...you may save a little tire wear, but your spending more than a few tires worth of $$ just to get adj. camber. You'll find that the reasonable neg. camber you get from those springs will actually give you a better handling feel. Your toe should be reasonable, but you can get it adjusted if the car is too twitchy.
~james
Old Oct 31, 2003 | 11:26 AM
Default Re: Camber question (SleepyEG)
ok
mikej94civex
Suspension & Brakes
May 27, 2010 05:49 PM
GUNNER666
Jul 28, 2004 08:26 AM
SMC Integra
Jul 30, 2003 01:49 PM
jdmrealm
Nov 28, 2001 11:29 PM
Chip398193
Jul 29, 2001 11:38 AM
