Camber question
I have a 94 ex and I bought cheap ebay coil overs. with tokico illuminas. well after installation I had just a bit of nevative camber on the front wheels. well the ride quality was bad so I now have eibach prokit. but do I need to get a camber correction kit before I install it or will the springs reverse the camber? to my understanding the drop isnt that low with the prokit and If I had used it before I wouldnt have the negative camber.
You probably won't suffer any lasting effects from the coilovers, but get an alignment anyway. The prokit lowers enough that you should get your toe fixed. Camber may not be a problem for you.
camber isn't adjustable on your car...Your best bet is to put the springs on, and see how the camber is, with the Prokits, it shouldn't be too bad, but if your worried about tire wear, buy yourself some camber kits...
what I've never understood about doing that is...you may save a little tire wear, but your spending more than a few tires worth of $$ just to get adj. camber. You'll find that the reasonable neg. camber you get from those springs will actually give you a better handling feel. Your toe should be reasonable, but you can get it adjusted if the car is too twitchy.
~james
~james
mikej94civex
Suspension & Brakes
May 27, 2010 05:49 PM
