cam seals???
Old May 17, 2004 | 07:23 PM
blueintegra90's Avatar
Default cam seals???
does anyone have instuctions on how to replace the cam seals on a 90 integra.
Old May 17, 2004 | 11:33 PM
hondatechnician's Avatar
Default Re: cam seals??? (blueintegra90)
remove ur valve cover and pop that sucker in
Old May 18, 2004 | 02:30 AM
4crx4me's Avatar
Default Re: cam seals??? (hondatechnician)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatechnician &raquo;</TD></TR><TR><TD CLASS="quote">remove ur valve cover and pop that sucker in</TD></TR></TABLE>
for the plug on the dizzy side. (get a P72)
The pulley side seals are a bit more complicated.
Old May 18, 2004 | 09:06 AM
kur0ryu's Avatar
you'll have to take the cam gears off to get the cam seals done. Loosen the timing belt tensioner, slip it off, undo the cam bolts and slide the gears off (careful of the woodruff keys falling into the timing belt plastic housing. if it falls in, you'll have to take the crank off!)
Old May 18, 2004 | 03:22 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueintegra90 &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have instuctions on how to replace the cam seals on a 90 integra. </TD></TR></TABLE>
these instructions are the best: http://www.helminc.com
MR Rodgers
Jun 26, 2007 09:46 PM
94 IntegraLS
May 25, 2007 04:41 PM
frankenstienEk
Jan 29, 2007 10:33 PM
DA is best
May 4, 2006 07:17 PM
sirminder
May 12, 2003 06:27 AM
