Cam seals
Old Feb 16, 2005 | 03:31 AM
BlkSIvic's Avatar
Default Cam seals
Is it possible to install new cam seals (at the cam gear end) with out removing the cams? Will I be able to just take the gears off and slide new seals in?
Old Feb 16, 2005 | 06:06 AM
NJIN BUILDR's Avatar
Default Re: Cam seals (BlkSIvic)
Yes,you don't need to remove the cams.You need to take off the cam caps that hold the seals.Put a little oil on the seal lips.Swap the seals.Put a small dab of hondabond on the edges of the cap near the seals..Replace and torque the caps back down.You know the rest.
Glenn
Old Feb 16, 2005 | 07:43 AM
BlkSIvic's Avatar
thanks
guymosiris
Mar 22, 2007 07:19 AM
TheWalrus
Jan 30, 2006 05:47 AM
TurbodCX
Dec 23, 2003 07:11 AM
whitelightning
Jan 17, 2003 08:07 AM
