Cam Gears
Old Mar 28, 2003 | 09:27 PM
Luserkid's Avatar
Default Cam Gears
Can someone give me a walk thru on how to put Adjustible cam gears on my B18C1? My problem is my belt, how could i take the belt off the cams without taking the engine mount off? Thanks.
Old Mar 28, 2003 | 11:03 PM
Malgerus's Avatar
Default Re: Cam Gears (Luserkid)
Well, you have to slip the belt around the engine mount to get it off... so you do have to unbolt it.
Old Mar 29, 2003 | 08:23 AM
Luserkid's Avatar
Default Re: Cam Gears (Mr. S)
Can anyone give me more info or a walk thru from start to finish on changing cam gears? Thanks.
Old Mar 29, 2003 | 09:18 AM
Quik Chris's Avatar
You don't have to undo the mount, but this is isn't a newb job.
Undo the timing belt tensioner, slip the belt off the top of the cam gears. You'll need an impact wrench to get them off. Install new gears. Slip timing belt back on, make sure it's in the exact place it was when you took it off. No skipping teeth = blown motor. Redo tensioner as read in helms manual.
If you don't know what I'm talking about, I'd get someone experienced to do/help you do it.
Old Mar 29, 2003 | 09:51 AM
Luserkid's Avatar
Default Re: Cam Gears (Quik Chris)
Oh so you cant get the cam gears off with out a impact wrench, cause i tried with a normal wrench but it just kept moving the cams. Thanks for the info, now im goin to just try to put my belt back on and get a impact to finish it off. Thanks.
*edit* What do i torque the Tensioner to?
[Modified by Luserkid, 6:56 PM 3/29/2003]
Old Mar 29, 2003 | 07:32 PM
Cory man's Avatar
pretty sure its 34ft-lbs.
Old Mar 29, 2003 | 08:03 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Cam Gears (Cory man)
watch trying to remove them with a wrench. if they walk too far and jump time it may be a little hairy to get them back if you havent done it before. a 3/8 impact usually does the job.
masospaghetti
Jun 26, 2016 05:45 AM
92EG8
Nov 2, 2008 03:41 AM
Racermech
Jun 25, 2006 04:33 PM
HamiltonRex
Nov 13, 2004 05:50 PM
KooK
Apr 8, 2002 04:24 PM
