CAI idea's and Q's
Old Feb 4, 2003 | 04:52 PM
Simple's Avatar
Default CAI idea's and Q's
Hey guys, im looking into the idea of making a custom CAI for my Civic. Its got a B20Vtec with a POS generic short ram. Well im getting sick of that... so i drew up some plans, and want to set them into work, but i have a couple questions.
1st. What diameter, and material to make the pipe out of.
-im thinking aluminum, and 3...3.5" with a 3 or 3.5" into 2.5 for the TB.
-whats the difference in diameter? will it REALLY make that much difference between a 3" to 4"; AEM seems to think it will with the new V2 design.
2nd. where should the filter to come out at?
-thinking the left front right behind the vent.
3rd. Ever seen those "Tornado" infomercials? "will get you better gas milage + HP" and blah blah blah... thinking of getting some 1" wide sheets, and twisting them, so it works like the tornado, which "spins the air" just for ***** and giggles
- only worry with that is if the damn thing comes un-welded and gets sucked up into the TB and IM.
Any suggestions, or ideas or comments welcome, and feel free to flame the "tornado" idea
Old Feb 4, 2003 | 05:00 PM
sslude's Avatar
Default Re: CAI idea's and Q's (Simple)
any thing that you put inside the intake wil slow flow down, in other words, "tornado" doesnt work. i guess you could use ABS plastic and heat resistant paint. i would go from 3" to 2.5" good luck
Old Feb 4, 2003 | 05:42 PM
Nameless RB26's Avatar
Default Re: CAI idea's and Q's (sslude)
I'd make some sort of cold air ram with a filter that drops into a slot or something.
Say you route some sort of tubing down to the bumper (area of your choice - I chose to cut out part of my 99 civic bumper), and then making some sort of slot to put a filter into. And then creating a heat shield of some sort. probably too much work and an AEM CAI would work better....
Old Feb 4, 2003 | 05:51 PM
hybridb18's Avatar
http://www.teamdelsol.com/howto/coldair/diycoldair.htm
Here this is everything u need to know
Old Feb 4, 2003 | 07:14 PM
tinkerbell's Avatar
Default Re: CAI idea's and Q's (hybridb18)
ha ha!!!
you be'at me to it!!!
this is everything you need to know...
t..
Old Feb 4, 2003 | 08:38 PM
G2turbo_terror's Avatar
Default Re: CAI idea's and Q's (tinkerbell)
thats all you really need, mandrel bent pipe, design it w/the least bends. I installed that heat reflective clothes dryer duct (non insulated) over my entire intake as a heat shield and in summer time it really made a difference, looked ghetto but it worked good.
Old Feb 4, 2003 | 09:09 PM
Simple's Avatar
Default Re: CAI idea's and Q's (G2turbo_terror)
wow, thats about as close as an exact match i could get with the AEM system, Would this also apply to 3 or 3.5"? same steps, different piping diameter
thanks a lot guys!
mortificationrock
12
Sep 11, 2009 09:47 PM
Chinchilla
Feb 23, 2003 09:21 PM
Simple
Feb 5, 2003 12:28 PM
capone8055
Aug 22, 2002 11:10 AM
dose
15
Aug 10, 2002 10:14 AM
