Cable vs hydraulic tranny
Old Jan 3, 2007 | 01:42 PM
Itzmy91Teg's Avatar
Default Cable vs hydraulic tranny
What are the pro's and con's between the cable and hydraulic transmissions? I basically have a del sol shell that i'm going to be dropping a motor into. I have a 91 integra in my backyard with the cable transmission so i'm wondering would i be better off taking that transmission and installing it in my del sol or getting a hydraulic transmission and putting that in? Help is appreciated, flaming is not.
Old Jan 3, 2007 | 02:53 PM
2slowGs-R's Avatar
id rather use a hydrolic tranny since it doesnt use cables...shifts faster and much better...with the shift linkage being a solid part instead of running cable lines from the shifter to shift from the tranny..i say buy a hydro tranny and be happy...just my opinion..
Old Jan 4, 2007 | 10:01 PM
PHDZINE's Avatar
Default Re: Cable vs hydraulic tranny (Itzmy91Teg)
If it's going in a race car with a very heavy pressure plate, it would be a good idea to use a hydro tranny because the cable tranny cable would probably break and cable tranny with a very heavy pressure plate loose consistency with engagement due to cable stretch...just my 2 cents.
Old Jan 4, 2007 | 11:03 PM
garageEF's Avatar
Default Re: (2slowGs-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2slowGs-R &raquo;</TD></TR><TR><TD CLASS="quote">id rather use a hydrolic tranny since it doesnt use cables...shifts faster and much better...with the shift linkage being a solid part instead of running cable lines from the shifter to shift from the tranny..i say buy a hydro tranny and be happy...just my opinion..</TD></TR></TABLE>
only the clutch is cable activated, it still uses solid links for shifting gears.
they still suk though, go hydrolic
Old Jan 5, 2007 | 06:47 AM
mmuller's Avatar
Mad Scientist
besides the cable thing 92+cable trannys are internally identical to hydro tranny's
92- cable trannys are weaker and best avoided
todaspec b
May 31, 2006 01:40 PM
91' LS-VTEC
Apr 19, 2006 12:48 AM
idriveadelsol7
Apr 22, 2005 05:19 PM
