a/c removeal
Old Dec 30, 2004 | 07:46 AM
RACEPAK's Avatar
Default a/c removeal
how can i remove the a/c radiator just for a few minutes to make a manifold fit test?
am i gonna need to fill the a/c system all over again?
best regards moshik gaimidi
Old Dec 30, 2004 | 08:24 AM
snatch's Avatar
Default Re: a/c removeal (RACEPAK)
If you remove that part of the a/c, you will have to open the lines and all the freon will come out. They are rigid lines too, so don't bend them.
Cliffs: No you can't, and yes you will.
Old Dec 30, 2004 | 08:43 AM
RACEPAK's Avatar
Default Re: a/c removeal (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">If you remove that part of the a/c, you will have to open the lines and all the freon will come out. They are rigid lines too, so don't bend them.
Cliffs: and yes you will.</TD></TR></TABLE>
are you sure
there is no other way?
and how about just take off the fan from the ac radiator? how can i do this?
best regards moshik galimidi
Old Dec 30, 2004 | 10:55 AM
RACEPAK's Avatar
ttt. i need help
Old Dec 30, 2004 | 11:53 AM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">a/c radiator</TD></TR></TABLE>
It's a condenser.
You're supposed to recover the refrigerant
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">am i gonna need to fill the a/c system all over again?</TD></TR></TABLE>
yes. You'll need a new reciever/drier (cylinder with the sight glass). Once the lines are reconnected you'll need a vacuum pump to remove non condensables.
IF YOU DON'T DO IT RIGHT YOU WILL HAVE PROBLEMS.
Old Dec 30, 2004 | 04:10 PM
RACEPAK's Avatar
Default Re: a/c removeal (eda6)
hello
i thought that i can just unplug the conector and put it (the condenser) on the valve cover or somthing for a few min's to try my new manifold
i never thought that i need to unhook the hoses.
and i never thought about recover it by myself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
It's a condenser.
IF YOU DON'T DO IT RIGHT YOU WILL HAVE PROBLEMS.</TD></TR></TABLE>
Old Dec 30, 2004 | 04:18 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">hello
i thought that i can just unplug the conector and put it (the condenser) on the valve cover or somthing for a few min's to try my new manifold </TD></TR></TABLE>
You can do that with the fan but not with the condenser coil.
Old Jan 3, 2005 | 04:24 AM
snatch's Avatar
You can do that with the fan but not with the condenser coil.</TD></TR></TABLE>
Right, you could with the fan but not with the condenser itself. The a/c lines that run to it are solid rigid lines that will not flex. Hence, it won't work to take the whole thing apart.
Old Jan 3, 2005 | 07:11 AM
RACEPAK's Avatar
thank you all for the answers.
i just took out the fan. 4 bolts
now the problam is the stock DP. i cant test if the turbo fit cause the pipe sitting too high so i dont have enough room for the turbo .
i guess i need to take out this pipe as well.
djspecter
Nov 26, 2007 12:27 PM
MAKK Performance
May 23, 2005 09:01 AM
NA JDM GSR
Mar 8, 2005 01:21 PM
AirWaveGT
Jan 1, 2005 09:07 AM
Mugen Mike
Sep 9, 2003 08:28 PM
