A/C condensor removal?
Old Mar 20, 2003 | 11:54 AM
Mugen Mike's Avatar
Default A/C condensor removal?
How difficult a project is this? The rest of the A/C has already been removed and I'd like to get rid of the condensor as well.
Old Mar 20, 2003 | 12:02 PM
yellow blur's Avatar
Default Re: A/C condensor removal? (Mugen Mike)
Just pulled my AC yesterday. The condensor removal is pretty easy.
Are the lines gone aswell or still connected? There are 2 silver hardlines on the condensor, one on each side. If those are removed, all you need to do is remove the radiator stay brackets and lift up the radiator and tilt it towards the firewall. You then have to remove a bar that supports the condensor and just lift it out.
Ed
Old Mar 20, 2003 | 12:20 PM
Mugen Mike's Avatar
Default Re: A/C condensor removal? (yellow blur)
Now I feel a little retarded
That piece is out. What is that big box underneath the dash?
Old Mar 20, 2003 | 12:35 PM
I left that piece in.
Old Mar 20, 2003 | 12:52 PM
SamB's Avatar
New User
Contains the chiller unit. On my car (JDM so may be different on USDM) you can take the chiller unit out of the box but you have to leave the box in place otherwise the fan/heater won't work.
The chiller unit itself weighs 1kg, maybe 2kg, up to you if it's worth it I guess.
Hope that helps.
Old Mar 20, 2003 | 01:06 PM
DutchITR1689's Avatar
It's called the Evaporator. You'll need the heater duct to put in the place of the evaporator. It's very easy to replace.
Old Mar 20, 2003 | 01:10 PM
AK94GSR's Avatar
Default Re: A/C condensor removal? (SamB)
yeah, i just took out my whole setup, but left that thing under the dash adn plug all the holes. I want to take it out since there really is no use for it. So if anyone is looking for any AC parts I will sell anything u need.
I would say the whole setup weighs 30 lbs if not close to that.
anyone else actually weigh the ac system????
Old Mar 20, 2003 | 01:13 PM
Reid's Avatar
Global Moderator
You need the air duct from an Integra w/o A/C, then you can remove it.
Old Mar 20, 2003 | 01:30 PM
Mugen Mike's Avatar
Default Re: A/C condensor removal? (Reid)
Thanks guys. Anyone have the part # for that air duct?
Old Mar 20, 2003 | 02:12 PM
SamB's Avatar
New User
Good idea, I just used racer tape to seal the holes - racer tape ownz me y0!
Old Mar 20, 2003 | 02:15 PM
Reid's Avatar
Global Moderator
Seal which holes?
There wouldn't be a hole, so much as a large gap.
Old Mar 20, 2003 | 02:50 PM
tecnic1's Avatar
there is not a part number. It is included with the dash assy. You can not buy the bridge seperately.....at least that was what we guessed after 45 minutes at the parts counter looking for the part number.
Old Mar 20, 2003 | 02:52 PM
Reid's Avatar
Global Moderator
Default Re: A/C condensor removal? (tecnic1)
I ordered my air duct and all grommets from Carland Acura.
Part #7 in the below picture:
Old Mar 20, 2003 | 03:07 PM
Mugen Mike's Avatar
Thanks again Reid
Is there anything you don't know
Old Mar 20, 2003 | 03:09 PM
SamB's Avatar
New User
Seal which holes?
The chiller sits in it's own seperate box which can be removed, then after taking the chiller thingy out of the box, you need to seal the holes which the solid a/c lines come in through. There is also a small hole for temp probe that seems to measure the chiller core temp or air temp.
You can then put the empty box back in place, so no gap.
P.S don't get me wrong, I prefer your approach, I'm not promote racer tape engineering
[Modified by SamB, 4:14 PM 3/20/2003]
Old Mar 20, 2003 | 04:59 PM
sackdz's Avatar
Weren't we just talking about this last week Reid?
Old Mar 20, 2003 | 06:31 PM
TypeR 01 886's Avatar
Default Re: A/C condensor removal? (sackdz)
A/C is a must in FL
Old Sep 9, 2003 | 01:12 PM
weraider30's Avatar
Default Re: A/C condensor removal? (TypeR 01 886)
sorry to bring up old posts, but the thing that looks like a radiator is the condensor? i thought that was the a/c cooler...let me know, thanks.
Old Sep 9, 2003 | 07:20 PM
Jason's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 01 886 &raquo;</TD></TR><TR><TD CLASS="quote">A/C is a must in FL</TD></TR></TABLE>
I never used mine...
here's the installation instructions for DC2 from Acura...reverse to remove...I believe the part number for the piece you are looking for is there too, I haven't looked at it in a while...For the record, I scanned it myself so I know it's accurate!
http://www.we-todd-did-racing....3D%3D
Old Sep 9, 2003 | 08:28 PM
sackdz's Avatar
Default Re: A/C condensor removal? (weraider30)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weraider30 &raquo;</TD></TR><TR><TD CLASS="quote">sorry to bring up old posts, but the thing that looks like a radiator is the condensor? i thought that was the a/c cooler...let me know, thanks.</TD></TR></TABLE>
The condensor sits in front of the radiator, acts just like a raidator. THe evaporator or "cooler" is under the dash and acts like the heater core, only its cold.
Jose-aka-Pedro
May 14, 2007 09:46 AM
londonsupra
Jun 30, 2006 05:22 AM
Grnade
May 20, 2005 09:14 PM
AirWaveGT
Jan 1, 2005 09:07 AM
GroundZer0 336
Jan 5, 2004 11:14 AM
