A/C failure questions!
Old Jul 15, 2005 | 07:34 PM
penguin's Avatar
Default A/C failure questions!
Ok, so my a/c is out. At first I thought it was the compressor or condenser but it might just be one of the hard lines. Irrespective of that; I heard through my father-in-law that the a/c compressor has a magnetic pulley that has to engage and unless that engages then there is no undue strain or stress on the compressor (which, even if it is ok the lack of refrigerant oil would eventually cause it to seize) then the clutch will spin freely. Thus, the belt won't slip because the clutch is spinning and not sitting in one place. Is this true? If so, how do I ensure the clutch/magnetic pulley never engages (maybe by never turning the a/c on??)? Any help would be great!
BTW, the car is a 2003 Honda Civic Si (k20a3).
Old Jul 16, 2005 | 04:14 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: A/C failure questions! (penguin)
What exactly are you trying to accomplish?
If you don't want the clutch to spin or engauge the compressor
just cut or remove the belt..
Old Jul 18, 2005 | 07:35 AM
penguin's Avatar
Default Re: A/C failure questions! (88DXCRX)
You can't exactly do that with a civic. Well, you can. But your car will overheat We use just one serpentine belt for everything. However, the problem is solved. The clutch won't engage if there is too low or too high pressure in the lines. Seeing that my lines are empty, the pulley spins freely. I have a bad O ring which will be replaced this weekend.
TitaniumCoder47
Aug 10, 2018 05:19 PM
immajackuup
Sep 11, 2008 07:16 PM
THALADOR
Jun 9, 2008 08:19 PM
barkwaffle
Aug 12, 2005 05:53 PM
