Bypassing knock sensor on a P72
Old Oct 5, 2003 | 01:04 AM
SiHatchTurbo's Avatar
Default Bypassing knock sensor on a P72
I have a OBD-1 ECU that I am using and I am trying to figure out what is the best way to bypass the knock sensor. I was looking at my D clip on my ECU and I didnt see any wire for my knock sensor so I was thinking of putting in a wire and trying to ground it but im not sure it will work.
Old Oct 5, 2003 | 08:20 AM
H23vtecEG's Avatar
Default Re: Bypassing knock sensor on a P72 (SiHatchTurbo)
nooooooooooo way hozzey cant go around it your car will run like crap without it
Old Oct 5, 2003 | 10:49 AM
T4eg's Avatar
you could get it chipped..so it wont need the knock sensor
Old Oct 6, 2003 | 01:01 AM
Fobtions's Avatar
Default Re: Bypassing knock sensor on a P72 (BlueHatch00)
throw a p28 on there, or u can have the sensor hang somewhere.
Old Oct 6, 2003 | 02:24 AM
H22A4_egHatch's Avatar
the shop that did my brother's LS/VTEC grounded out his knock-sensor,which in turn disabled his VTEC.....so his car was basically running like a stock LS.we went to another shop and they said that the problem was that the knock sensor was grounded out.after replacing it,the car runs just fine now......so I don't recommend it,buddy.
Old Oct 6, 2003 | 11:11 AM
Thanks for yall's help.
Old Oct 10, 2003 | 09:56 AM
dwnthehatch's Avatar
Default Re: (SiHatchTurbo)
I suggest that you sell your P72 and you'll have enough for a chipped P28.
Old Oct 11, 2003 | 01:03 AM
how much do chipped p28s usually run
Old Oct 11, 2003 | 08:04 AM
LudeyKrus's Avatar
How does the knock sensor work?
Could you not just stick a resistor in to fool the ecu?
Old Oct 11, 2003 | 10:22 AM
PHiZ's Avatar
Default Re: (LudeyKrus)
Disable it with a chipped ecu. Your car will run fine without it, whoever said that is a moron.
chipped P72 if you have an IAB equipped intake mani, chipped P28 otherwise.
-PHiZ
Old Oct 11, 2003 | 10:24 AM
Kataku2K3's Avatar
Three easy options, #1, Chip a P28 for yourself, #2. tap the block and wire up the KS, #3. Find a proggy which you can chip it out of your P72 with... My choice would be to go with a P05/06/07/28 chipped to DOHC VTEC specs... I hate the stock P72 tho... As for a KS, it's a piezo electrice device which creates voltage as it is "stressed" (or vibrated in our case), the ECU interprets high levels of stress as a knock, ping, etc... There's no fooling the ECU with a resistor or even grounding a sensor and running the wire to your KS pinout... The stock KS does however not work with a damn for saving your motor against detonation... That's why I just say SOHC ECU Good Luck and I hope this helps
CiviCVuE
Mar 13, 2007 06:00 PM
96 GSR-T
Jun 30, 2006 09:31 PM
Hartattack
Dec 19, 2005 05:46 PM
dsowers19
Sep 6, 2005 10:22 PM
BoostedSOHC
May 12, 2003 09:01 AM
