built motor flooded by katrina
Old Sep 8, 2005 | 05:41 PM
turbob16crx's Avatar
Default built motor flooded by katrina
i know the computer and msd box are gone but is the motor saveable. what to do if it got into the intake. how do i get it back to life. i stay in new orleans and now i live in houston since katrina and since there is still water in the city i cant get to my baby. what do i do when i get her back. also anyone in houston or near that may be of some asistance. i cant just call it a loss i have a couple thousand in the motor, and where i stay now i hear them running at night and i cant take it without my car. please help
Old Sep 8, 2005 | 08:28 PM
h22 civic's Avatar
Default Re: built motor flooded by katrina (turbob16crx)
that sux
Old Sep 8, 2005 | 09:04 PM
Louie's Avatar
What would Chente do?
if you can get it cranking, remove the plugs and blow out the cylinders. Use air to remove the rest. throw some wd-40 to avoid rust and you should be ok. i guess i depends how high the water was. then you'll have to drain the oil and stuff. sorry about your situation....hope it gets better soon. peace.
Old Sep 8, 2005 | 09:40 PM
PrettyLude's Avatar
**** the water is high to the roof of the houses around here in certain areas
Old Sep 8, 2005 | 09:43 PM
gsrious's Avatar
i hpoe you can salvage all the parts of your car. hell, even your whole car.
if i were in your case, i would probably disassemble everything and clean all of it. basically a rebuild again(just for assurance).
Old Sep 9, 2005 | 03:30 AM
BigMoose's Avatar
Don't give up on the ecm right off the bat. Open it up, rinse it well with distilled water, then dry it out very well. Blow it down with compressed air, even "bake it" a bit with a flood lamp a foot to 18 inches away, don't overheat it, like over 130 degree board temperature. Power it when dry. The thing I am not sure of is if the barometric pressure sensor can handle being submerged.
Old Sep 11, 2005 | 01:10 AM
t72vtec's Avatar
Hey sorry 2 hear that, but if i was u i take my head off and clean everything inside out and u should be alright, dry your distributor with a hair dryer and the plugs i think your ECU is gone you might need a new 1 if i was there in Houston i would give u a hand 4 sure, GOOD LUCK !
Old Sep 11, 2005 | 09:51 AM
animal chin's Avatar
Default Re: (t72vtec)
sorry about that,,,,,wasnt aiming for you
Old Sep 11, 2005 | 11:12 AM
Fkned's Avatar
As long as the motor isn't turned over you'll be ok even if it's full of water.Just take the motor apart and clean it out you should be ok,I'd change the rings/bearings/gaskets/seals and get a slight hone to be safe though.
Old Sep 12, 2005 | 07:13 AM
b16hybridsol's Avatar
Default Re: (katrina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katrina &raquo;</TD></TR><TR><TD CLASS="quote">sorry about that,,,,,wasnt aiming for you
thats fucked up man g'luck
Old Sep 12, 2005 | 05:24 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (Ed's Racing Heads)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed’s Racing Heads &raquo;</TD></TR><TR><TD CLASS="quote">As long as the motor isn't turned over you'll be ok even if it's full of water.Just take the motor apart and clean it out you should be ok,I'd change the rings/bearings/gaskets/seals and get a slight hone to be safe though.</TD></TR></TABLE>damn.. why did leave ur car in NO and not take it to Texas?
Old Sep 12, 2005 | 11:39 PM
bump
projekt-sol
18
May 1, 2008 11:37 AM
Kjoram
Sep 21, 2006 07:30 AM
flyingduck04
Mar 3, 2006 06:55 PM
flyingduck04
Feb 28, 2006 05:54 AM
V-SPEC 1
Feb 9, 2003 06:28 AM
