Building Brakes
Old Sep 20, 2006 | 03:10 PM
eg6madness's Avatar
Default Building Brakes
i remember some time that someone was taking off the drum setup on Civics and getting rear disc and bolting them onto the rear arm , i think with a spacer, and using block to mount the caliper.
does anyone have any info on this setup .
I have an EG civic with rear drums and i have GSR disc and lud calipers at my disposal, i would like to know if anyone know how i can rig up this setup to replace my drums.
Old Sep 20, 2006 | 03:32 PM
Amped's Avatar
Default Re: Building Brakes (eg6madness)
You need the trailing arm and hub from a gsr. You also need the brake booster& master cylinder with the proportioning valve from a gsr. I know you can learn how to do it on Hybridgarage.com i think.
Old Sep 20, 2006 | 08:14 PM
JimBlake's Avatar
Default Re: Building Brakes (Amped)
Any Integra except Type-R. The LS & GSR have the same brakes. Well, that's true for '94 & up anyway. A type-R setup has 5-lug hubs which would give you problems fitting your wheels.
Old Sep 21, 2006 | 09:34 AM
eg6madness's Avatar
Default Re: Building Brakes (JimBlake)
ok so i can remove my drums and just use the teg rotors and calipers....
is the hub center goin to be the same?
Old Sep 23, 2006 | 11:08 AM
Amped's Avatar
i think you need the trailing arm though
Old Sep 24, 2006 | 07:51 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Amped &raquo;</TD></TR><TR><TD CLASS="quote">i think you need the trailing arm though</TD></TR></TABLE>Yes, I think so too. I only meant that you can use the trailing arms & all from ANY Integra, not just a GSR.
nickelz34
Aug 22, 2013 05:07 PM
OEMJDM
Suspension & Brakes
Feb 10, 2010 07:06 PM
jerry_ort007
May 20, 2009 03:39 PM
jrockets
Jan 17, 2007 02:03 PM
JDiMageDC2
Nov 4, 2002 01:50 AM
