broken vac. connector
Old May 4, 2005 | 07:26 PM
LSVtechnologytur...'s Avatar
Default broken vac. connector
Well i was just hooking everything up on my motor when i noticed this connector was completly snapped off. (this isn't a pic. of my car, but that metal piece is flush with the rest of the intake mani
im not sure if it was broken when the head was shipped to me, or before that... but how can i fix it?
thanks
Old May 4, 2005 | 08:55 PM
PrettyLude's Avatar
use an easy out to pull it out, pretty easy to do
Old May 6, 2005 | 01:10 PM
Default Re: (PrettyLude)
Could i " T " off of any other vacuum sources?
Old May 6, 2005 | 08:51 PM
eda6's Avatar
Default Re: (vtec'n)
Go to the junkyard and find that vacuum port on an intake mani.
Those fittings can be heated up and removed with mapp gas and channel locks. Just heat it up, then pull and twist at the same time. If you do this take a fire extinguisher. After i found one at the junkyard, i took it to a machine shop and they fixed it. The best way to fix it IMO.
MikeLuder
Mar 29, 2009 12:37 AM
patrickstar
19
Oct 9, 2007 07:46 PM
Sassafrass
14
May 24, 2006 03:04 PM
20civic00
Mar 6, 2006 06:30 PM
