broken stud in block? Help
Old Mar 28, 2008 | 06:48 AM
ccssk8ter11's Avatar
Default broken stud in block? Help
not sure if this is in the right section but I started installing my turbo kit the other day and when I was taking the old exhaust manifold off one stud broke off about a quarter inch off in the block. What is the easiest way to get it out?? I was just gonna drill it and use an easy out but the only drill I could find that would fit right isnt very powerful ( it is the stud farthest to the right and I have an f22 so there isnt much room between the head and the alternator) I drilled for what seemed like hours and barely made any progress and the bits keep breaking. Do I just need a better drill/bits or is there an easier way to do it?
Old Mar 28, 2008 | 12:34 PM
JDM Lyfestyle's Avatar
Default Re: broken stud in block? Help (ccssk8ter11)
I assume you mean where the manifold bolts to the engine which would be the head not the block as your title says..
Its almost impossible to drill out bolts like that with a regular drill bit,you would need like a carbide tip bit or similar and a decent drill.It would be easier for you if you remove the alternator
If you have access to welding equipment it is possible to weld a nut onto the end of the stud then simply unscrew as if it was a bolt.it does take some skill though.
Old Mar 28, 2008 | 04:46 PM
Yeah i realize its the head not the block, my mistake. I already removed the alternator and there still isnt very much room lol. I would put a nut on it but its broken off inside the hole.
Old Mar 28, 2008 | 04:57 PM
blkb18's Avatar
Default Re: (ccssk8ter11)
You can get a extractor kit probably from sears, I got mine from my snap on dealer. They make a few different kinds, but they all work pretty much the same way. You drill a specific size hole (as specified by the extractor kit) as centered as possible in the broken off stud. Then you put the extractor in the hole (will have to be tapped in with a hammer), and twist off. A little heat may help also. Good luck.
Old Mar 28, 2008 | 05:27 PM
yeah thats pretty much what the easy out is. Its just hard as hell to drill the stud. I guess i just need a better drill/bit.
4g4dcruisin
10
Sep 26, 2012 09:30 AM
steven_highet
Jan 25, 2009 11:47 AM
Soon2bH2b
Sep 26, 2007 05:43 AM
skiracer8148
17
Apr 1, 2007 09:17 PM
boostedsol
Jan 11, 2003 03:18 PM
