broken motor mounts on 94 gsr
Old Sep 13, 2005 | 04:14 AM
HKSone's Avatar
Default broken motor mounts on 94 gsr
I have a 94 gsr swap ready to go into my 92 hatch, but the rear rubber mount, the a/c rubber and lower tranny rubber mount are broken. I believe they are the torque mounts, my question is will they be useable after I put in the energy suspension urethane mount inserts, or i have to get new factory ones? I was already going to plan to get the inserts anyways. Please let me know need to get swap in.. thanks
Old Sep 13, 2005 | 06:42 AM
mmuller's Avatar
Mad Scientist
Default Re: broken motor mounts on 94 gsr (HKSone)
they will work after you put the inserts in.
Old Sep 13, 2005 | 04:29 PM
HKSone's Avatar
Default Re: broken motor mounts on 94 gsr (mmuller)
thanks, also I forgot to mention I have the civic rubber torque mounts from the car as well, will they work with the gsr metal mounts or the energy suspension inserts?
Old Sep 13, 2005 | 05:56 PM
mmuller's Avatar
Mad Scientist
your supposed to keep your civic front torque mounts. you can use the gsr ones; but your going to have to grind the petruding thingie..youll see
and yes, the are the same poly torque mounts for both
Old Sep 15, 2005 | 03:35 AM
HKSone's Avatar
cool I guess I'll just use my civic mounts; thanks alot..
92lxsleeper
Jul 29, 2009 08:28 AM
paul8ex
Mar 14, 2009 07:45 PM
Kaspk
17
Jan 19, 2008 06:54 PM
whoneedzvtec
Nov 21, 2007 04:13 AM
SneezR
Jul 13, 2005 05:39 AM
