Breather
Old May 7, 2002 | 08:08 PM
Turbo Powa's Avatar
Default Breather
Where does the breather go for a D series honda civic? I'm just curious to know what it does and how it improves performace. I hope you people can help..... can you also post pics? Thanks!!
[Modified by Civic LX 29, 5:19 AM 5/8/2002]
Old May 7, 2002 | 09:41 PM
Kamin's Avatar
Default Re: Breather (Civic LX 29)
it goes on the tube from the valve cover to the intake.
it dosent to jack S#*% for performance. it probably hurts it because oil can come out of the breather.
i took mine off a while ago.
Old May 8, 2002 | 01:20 AM
B18C-EJ1
Guest
Posts: n/a
Complete waste of $$$. Spend your money elsewhere.
Old May 8, 2002 | 01:52 AM
MikeSarr_GSR's Avatar
Default Re: Breather (B18C-EJ1)
over time, it will help reduce PCV drainage into the manifold and burning
oil fumes in the motor. if you have increased compression and/or revs
this will help reduce the possibility of detonation of PCV fumes.
I suggest one, they are only like 2-5 bucks man I ran mine on the back
of the stock breather that connects to the stock intake tube. It is hidden
from view.
Old May 8, 2002 | 04:57 AM
StyleTEG's Avatar
Default Re: Breather (MikeSarr_GSR)
If you are having problems with detonation of PCV fumes, or carbon buildup in your TB and Intake manifold.. just get an oil catch can.
Old May 8, 2002 | 07:09 AM
Turbo Powa's Avatar
Default Re: Breather (StyleTEG)
Thanks Guys!!
chitownbluEG
23
Feb 24, 2014 06:57 AM
Edwin909
10
Jun 21, 2011 09:04 PM
ivan93egreppin210
Feb 11, 2008 10:20 AM
DC5 Demon
Mar 25, 2006 08:24 AM
steve-o40
Apr 8, 2004 08:11 PM
