Breaking in new cams
Old Jul 17, 2004 | 02:12 AM
toy's Avatar
toy
Default Breaking in new cams
Hi
I did a search, but it offered more questions than answers.
I have just installed some Toda C cams and want to know how to break them in?
I know normal cams are run in at about 2000rpm for about 20 minutes, but I can't find any information on the Toda cams.
Thanks
Old Jul 17, 2004 | 07:20 AM
Humble1's Avatar
Default Re: Breaking in new cams (toy)
just break them like as if were an oem cam.same procedure.cam is a cam.i dont see a difference.
Old Jul 17, 2004 | 08:53 AM
Kendall's Avatar
With the Toda C's, I would keep it revved for the first 500 miles just to be on the safe side. Don't let it idle any longer than necessary.
Old Jul 17, 2004 | 11:44 AM
accorse07's Avatar
not really a break in required...cams are cams...just make sure you set the valve lash correctly and don;t leave it loose...can snap your timing belt or damage your tensioner pulley.
Old Jul 17, 2004 | 11:47 AM
STG3PWR's Avatar
Default Re: Breaking in new cams (accorse07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accorse07 &raquo;</TD></TR><TR><TD CLASS="quote">not really a break in required...cams are cams...just make sure you set the valve lash correctly and don;t leave it loose...can snap your timing belt or damage your tensioner pulley.</TD></TR></TABLE>
Old Jul 17, 2004 | 12:12 PM
Sliced Beard's Avatar
Default Re: Breaking in new cams (ADVANcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">With the Toda C's, I would keep it revved for the first 500 miles just to be on the safe side. Don't let it idle any longer than necessary.</TD></TR></TABLE>
listen to this one
1QwIkEf
Jul 23, 2010 08:26 AM
kallmotor
Aug 22, 2004 07:10 AM
93solsigsr
Apr 29, 2003 06:34 PM
GreenR
Apr 22, 2002 11:54 AM
