Breaking in ACT HDSS, tips ?
Old Apr 20, 2005 | 09:06 AM
X2BOARD's Avatar
Default Breaking in ACT HDSS, tips ?
I searched and read some break-ins regarding the puck clutches, but I'm going with a HDSS, street disc, full face, sprung.
I am putting in the clutch today and can't find the ACT tip sheet, so what's the best way to do it ?
What I know:
Drive 500 miles, stop and go style, not highway
Go easy on the engagement
No racing, no quick starts, no hard shifting.
But what about rpm and speed ? Am I not supposed to go past specific points for the clutch's sake ?
Do I slip it at all or go with a firm, quicker engagement ?
Can I REALLY race after 500 miles ? I need to get this puppy broken in for an event on sunday.
Old Apr 20, 2005 | 09:39 AM
riceisnicenv's Avatar
Default Re: Breaking in ACT HDSS, tips ? (X2BOARD)
from what i've read you are supposed to keep the shifts under 4krpm. i'd slip the clutch like you would normally (a small amount). i would not recommend holding the car in one spot on a hill with the clutch and throttle or downshifting hard. if you're gunna downshift then rev match and slip a little. that should do it. if you do 500 miles of stop and go traffic that should be ready for a sunday event. good luck
Old Apr 20, 2005 | 10:40 AM
drdisco69's Avatar
Default Re: Breaking in ACT HDSS, tips ? (riceisnicenv)
As long as the clutch is engaged, it could be spinning at 15,000 rpm and not give one ****. If there is no relative movement between the disc and the flywheel and pressure plate, nothing is happening to the clutch.
City traffic, take off easy, shift without slipping and it will be a happy clutch. Don't worry about RPM specifially, just make sure when you shift, you don't drag the rpm down when you reengage the clutch.
Old Apr 20, 2005 | 02:32 PM
X2BOARD's Avatar
Default Re: Breaking in ACT HDSS, tips ? (drdisco69)
Thanks for the input riceisnicenv....makes sense
Disco... you say that once engaged it doesn't matter the rpm, but I'm concerned since teh clutch isn't particularly seated yet, might it slip at lets say 6k+ ? Either way, I think I'll keep her under 6 grand.
Old Apr 20, 2005 | 04:10 PM
drdisco69's Avatar
It won't slip, unless you have a LOT of power. Either way, you can't go wrong by staying under 6k.
Old Apr 21, 2005 | 03:03 PM
X2BOARD's Avatar
Thanks everyone. This street disc is much easier to engage that my old puck clutch... but he ACT HD PP is surprisingly stiff !
I've clocked about 50 miles so far before an injector problem came up... got it cleaned out and all systems are a go.... imma put on the remaining 450 miles in the next two days.... ay yai yai...
Old Apr 21, 2005 | 08:03 PM
blackeg's Avatar
i started off real gentle on my hdss break in. i went like a lil less than 100 miles shifting below 3k rpm, then by like 350 miles i had it up to easy shifts at 5 grand. i think i went a tiny bit shy of 500 miles before i started dumping it and driving like an ***. it held out fine for like 25k miles unboosted and about 1000 on the snail
Old Apr 22, 2005 | 08:33 AM
X2BOARD's Avatar
I still wonder which way is best for grip and longevity, cuz i've been talking with other mechanics and each one has a slightly different take on it...lol
esca
Feb 26, 2005 02:42 PM
VisPreludeVtec
Sep 18, 2004 06:40 PM
White S2k
17
Apr 30, 2003 11:17 AM
LOwrestling2001
May 28, 2002 08:25 AM
Lei Siew Long
Oct 7, 2001 02:25 PM
