Breakin period of an engine
Old Oct 31, 2003 | 02:17 PM
mattb16a1civic's Avatar
Default Breakin period of an engine
Im in the middle of rebuilding my b16a rings and bears and cams, I was wondering what would be the proper procedure to break in the rings, as far as what mileage what rpms and so on. Also do I need a cam lube when installing new cams(ctr)
Old Oct 31, 2003 | 04:21 PM
doublejz's Avatar
Default Re: Breakin period of an engine (mattb16a1civic)
Use a non detergent oil for about 1000 or so miles, some people recommend changing oil after the first 500 miles. Yes you should use cam lube. Always use cam lube even if it was just to remove the cam to look at the lifters and then replaced.
Old Oct 31, 2003 | 04:31 PM
i know about the non detergent oil im asking more of what rpms to drive at
Old Oct 31, 2003 | 04:32 PM
damnit gotta stop hitting enter, anyways i was wondering rpm range for what amount of time, some ppl say under 3k for 250 miles than 4 or so at 500, im just wondering what ppl say, the engines we built just for dyno use we just ran them at 2500 for 10 mins and that was considered our break in time, but they were only tested for 3 weeks.
Old Oct 31, 2003 | 06:03 PM
doublejz's Avatar
Default Re: (mattb16a1civic)
http://www.mototuneusa.com/break_in_secrets.htm
Old Oct 31, 2003 | 09:04 PM
Big Teggie's Avatar
Search
There is alot of good info you can find about different break in methods.
Old Nov 1, 2003 | 07:12 AM
1 2 NV's Avatar
let car warm up givin it 4k bursts in neutral. take out of garage and stomp on it. rings will seal up after doin this a few times.
Old Nov 1, 2003 | 09:55 AM
I was reading that on mototune and that makes sense to me, same thing a buddy of mine told me to do said thats how he used to break in his nissan race engines, Anyone else have any opinions on that article? oh and also doing 4k nuetral revs isnt my thing, I dont put that much stress on my engine without a load on it, just something I was told in school that if your gonna rev it have a load on it. if that works for you then thats fine, but I have to drive this thing and im kinda sick of putting new engines in it.
Old Nov 1, 2003 | 10:09 AM
1 2 NV's Avatar
revvin it in neutral is just to help seat the rings and promote all parts to "settle" in their fresh home. the real reason u rod on the engine right after its initial warm up is just to finalize seating. if u talk to most old school engine builders they will tell u to do the same thing. u can see compression build up after each pass until full vacuum is attained. then u know ur rings have seated properly.
vinyldude
K Series
May 2, 2016 07:19 PM
95_Civic_4dr
Apr 30, 2010 03:03 PM
ur31337
Apr 21, 2005 08:52 PM
an2ny888
Feb 20, 2005 06:06 AM
civicracer1993
May 19, 2003 06:07 PM
