Brake question...
Old Jul 2, 2002 | 06:04 AM
nixadm's Avatar
Default Brake question...
I recently slide off the rode into a sandy dirt ditch, which got all down my right side of my civic. since then when I brake it sounds & feels like i dont have any pads(grinding metal). I know its just sand but will it eventually wear off or do i have to replace my pads?
I checked the pads last night, still got plenty of pad left.
Old Jul 2, 2002 | 11:50 AM
ILUVTEC's Avatar
Default Re: Brake question... (nixadm)
First try and spray a good amount of brake parts cleaner all over (just dont get too direct/concentrated on the pads) and see if that helps. But there is a chance that you dislodged or 'hurt' something else(maybe the pads/retainers), just check everything else out, take off the wheel and look and feel around and see if anything is out of place. Hope it helps
Old Jul 3, 2002 | 05:42 AM
nixadm's Avatar
Default Re: Brake question... (ILUVTEC)
on the pads directly? or on the disc and spin the wheel so it gets it on the pads?
they appear to be correctly installed still, but a large amount of sand was in the wheels. it squeaks when im not even pressing the brakes.
Old Jul 3, 2002 | 11:41 AM
keithv's Avatar
i would just pull the pads off and see if there is alot of sand in there. its a pretty easy job, so its better to be safe and clean all that sand out.
Old Jul 3, 2002 | 11:46 AM
Spade's Avatar
Default Re: Brake question... (breaka_1_9)
Also feel the rotors for roughness, if there is you need to have them turned and replace the pads. DO NOT REUSE THE PADS!!!!
Old Jul 3, 2002 | 11:55 AM
B19CivicHB's Avatar
Default Re: Brake question... (Spade)
vtec128
Oct 20, 2009 07:57 AM
EG694Si
Dec 20, 2007 09:49 PM
verycleanhatch
Jan 9, 2007 04:15 PM
LshatchTurbo
Feb 19, 2002 08:53 PM
