brake problems
Old Aug 15, 2004 | 10:45 AM
AMChev's Avatar
Default brake problems
When I sit in traffic the pedal gradually goes all the way to the floor. Once it bottoms out the car starts to creep. I can pump the pedal and have brakes again but it gradually goes to the floor every time.
I did the functional test that is described in the 91 Civic service manual, with the engine off and pumping the pedal a few times then holding, the pedal sinks. The book says it's either a line, wheel cylinder, or the master cylinder.
I'm leaning towards the master cylinder because I'm not loosing any fluid. I think I'd notice fluid loss if it were a wheely cylinder or a line.
BTW, the booster passes all the functional test
Old Aug 15, 2004 | 11:02 AM
GaRn's Avatar
replace the master cylinder would be the first step i did.. I think you can get htem for under $100, maybe less with a core exchange..
Habeed
May 1, 2010 04:43 AM
mattbatson
Oct 23, 2008 07:30 PM
PreludePhill
Mar 22, 2007 06:22 PM
bambam
15
Jun 20, 2005 06:14 AM
cjohnson_2
Jul 11, 2003 08:10 PM
