BRAKE PEDAL SINKS?????? HELP
Old Mar 4, 2005 | 09:23 PM
solk1dd's Avatar
Default BRAKE PEDAL SINKS?????? HELP
Let say I'm at a light waiting w/ my foot on the brake pedal.
The Pedal just sinks all the way down and I start to roll So I let go and the brakes are hard again next 5 seconds later it starts sinking again and i start to roll again what could be the problem????
Old Mar 4, 2005 | 10:09 PM
PrettyLude's Avatar
master cylinder is going bad
Old Mar 5, 2005 | 01:08 AM
Deluzional's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">master cylinder is going bad</TD></TR></TABLE>
I had the same problem, I changed my brake fluid like twice until coming to that conclusion
Old Mar 5, 2005 | 04:44 AM
chandler's Avatar
also check the booster, if the fluid leaks back into it, it will eat the rubber diafram
Old Mar 5, 2005 | 10:28 PM
PrettyLude's Avatar
Default Re: (chandler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chandler &raquo;</TD></TR><TR><TD CLASS="quote">also check the booster, if the fluid leaks back into it, it will eat the rubber diafram</TD></TR></TABLE>
the chances of those going out are slim and none, your master cylinder will fail way before you booster will fail
Old Mar 6, 2005 | 07:45 AM
DavidT or VajT's Avatar
Bleed your brakes
Old Mar 6, 2005 | 12:19 PM
JdmEKCivic's Avatar
Default Re: (DavidT or VajT)
He's right
Old Mar 10, 2005 | 08:34 PM
92HB_HB's Avatar
Default Re: (JdmEKCivic)
if ur losing fluid, then there's a leak in the lines, else ur master cylnder is leaking internally..
had this problem on my teg last week.. turned out my hard lines going to the rear brakes rusted through and need to be replaced.. i ended up redoing the lines from the firewall back to the rear brakes..
Old Mar 10, 2005 | 09:35 PM
FalkenSiR's Avatar
Default Re: (92HB_HB)
By experience
Old Mar 13, 2005 | 09:32 PM
solk1dd's Avatar
Okay. I changed the master cylinder, took it from my old integra which was working well no problems.
The pedal doesn't sink in anymore, but NOW the pedal is only hard when it is an inch from the floor.
Old Mar 14, 2005 | 06:55 AM
JimBlake's Avatar
Default Re: (solk1dd)
Now this time you either left some air bubbles in (bleed it some more), or your MC is the wrong size.
Old Mar 14, 2005 | 10:00 AM
Atheist's Avatar
Bleed the breaks for sure
Old Mar 28, 2005 | 03:49 PM
JohnnieChimpo's Avatar
Default Re: (Atheist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solk1dd &raquo;</TD></TR><TR><TD CLASS="quote">Okay. I changed the master cylinder, took it from my old integra which was working well no problems.
Just had the same thing happen to me.
Not all Mater Cylinders are the same. Take a measurement of the hole in the center of the master cylinder, for depth. There was a 1/2 inch difference between the two I had. From the outside they looked exactly the same. Either adjust your pedal down under the dash where the clip mounts the brakes to the pedal or make a shim to go down in the hole to take up the space.
93b20z
Oct 18, 2008 11:56 AM
roller3804
Jun 25, 2008 06:20 PM
jeffruby
Jun 28, 2007 06:56 AM
s10cky
17
Dec 20, 2006 07:19 PM
SiR-G96
Dec 21, 2003 09:17 AM
