Brake Bleeding Techniques
New User
So...how do you all bleed your brakes and clutches??? Anyone used one of those speed-bleeder things??? Those gun type things i mean. I am considering getting one, but If they're not worth it, I don't want to spend the money. I already have this little bottle bleeder thing, but it doesn't do much for the firmness of the pedal.
http://www.nipponpower.com
20 bucks for a pair of brake bleeders, u leave them on the brakes and bleed when needed...speed bleeders..
I got a aquarium check vavle, $1.99, works great. Try to replace your fluid with ATE superblue, and if you can find a place that sells it, let me know, since we live close to each other.
If you guys have multiple cars, or have to bleed your brakes often..Or you just want the best and easiest tool for the job.
Get this:
http://www.motiveproducts.com/
I've worked with speedbleeders, and I've worked with this thing. This thing by far is the easiest to use, and the quickest. It's $45..but worth it, if you bleed often, or have multiple cars (because you can move these from car to car, unlike the speedbleeders).
Get this:
