BOILING WATER PROBLEM!!!!
Old Nov 4, 2003 | 07:30 PM
Honda_RN's Avatar
Default BOILING WATER PROBLEM!!!!
Don't have a clue whats going on.. I have a 96 automatic integra.... I traded a truck for it off this guy... I know it has some problem but didn't know its that serious.... well basically I put water into the radiator and drive it around for a couple of days and then all of a sudden I hear the water boiled like crazy.... I then poured water into it and same thing happends.. and my water dissapears without and visible leakage anywhere.... any solution?? some guy said that I have a bad head or something like that..
Old Nov 4, 2003 | 10:42 PM
99silverbullet's Avatar
Default Re: BOILING WATER PROBLEM!!!! (Ringbearer020)
sounds like a blown headgasket or a mabey a crack in the cylinder walls. does the car smoke at all?
Old Nov 4, 2003 | 11:20 PM
SC0TT's Avatar
When i first finished my swap, the coolant in the radiator was boiling...even in the overflow tank. Turned out i had a leak in the fins and boiled from lack of water. I'd check for leaks if your having to fill it.
Old Nov 5, 2003 | 07:53 AM
Littleton's Avatar
Default Re: BOILING WATER PROBLEM!!!! (SC0TT)
Change the radiator cap.
Old Nov 5, 2003 | 05:47 PM
3rdGteg's Avatar
Default Re: BOILING WATER PROBLEM!!!! (Littleton)
Do a leakdown test.
Old Nov 5, 2003 | 07:09 PM
sleepN's Avatar
pouring water while the engine is hot is a big no no, you may have warped the head really bad.
Old Nov 5, 2003 | 07:20 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Littleton &raquo;</TD></TR><TR><TD CLASS="quote">Change the radiator cap. </TD></TR></TABLE>
might do it. water boils at a higher temp when it is under pressure (the cap holds the pressure).
Old Nov 5, 2003 | 08:05 PM
Honda_RN's Avatar
thx guys.. I'll try a new cap soon as possible.... hopefully thats the case.. some guy told me its like the head or something.. dont' i dont' think the bastard knows wth he is talking about... oh yea.. no smoke or anything.. the car seems to run perfectly fine like nothing is wrong with it.. aight any other suggestions??
Null zahlen
19
Sep 14, 2009 02:10 PM
jdmej814
14
Mar 11, 2009 01:31 PM
accord23
Jun 2, 2007 10:01 AM
goowakjai
Aug 2, 2005 08:59 PM
Oracle17
Oct 10, 2003 09:44 AM
