Boggin problems
Old Jun 30, 2002 | 09:32 PM
XxR0myxX's Avatar
Default Boggin problems
i have a b16a and its boggin, my mechanic told me that it's my o2 sensor and my knock sensor. I was just wondering if that my the problem then what else could it be?
Old Jun 30, 2002 | 10:24 PM
LshatchTurbo's Avatar
New User
Default Re: Boggin problems (XxR0myxX)
Are you bogging from the start? When you just start the car? When your at WOT?
Old Jul 1, 2002 | 08:24 AM
AllMotorMadness's Avatar
maybe your running too rich
Old Jul 1, 2002 | 07:07 PM
XxR0myxX's Avatar
Default Re: Boggin problems (lshatchturbo)
Boggin starts when i turn the car on.. mechanic said it could maybe ma knock sensor and o2.??? if aibt that then what else could it be?
Old Jul 1, 2002 | 07:23 PM
.MilanoRex's Avatar
hi, i have a bogging problem when i take off... it sounds like a wet bubbly fart until i rev it to 4-5k... what could be wrong?
Old Jul 1, 2002 | 07:44 PM
New User
Default Re: Boggin problems (crXtreme)
what year is the car and motor?
Old Jul 1, 2002 | 07:55 PM
.MilanoRex's Avatar
89 CRX Si, stock d16a6 with 120k miles
Old Jul 1, 2002 | 08:15 PM
New User
Ahh okay. I did a swap with a freind, 1st gen b16 in a EF, it was bogging to the point where it would stall. I replaced the fuel filter, check the o2 sensor and still did it. In the end, it was the MAIN RELAY. Check your main relay, i bet that is the problem. After 8 years or so, there toast. And also check the CAT as well.
[Modified by lshatchturbo, 9:25 PM 7/1/2002]
Old Jul 2, 2002 | 01:45 AM
88_SC_CRX_Si's Avatar
New User
Take a "real" close look at the cam/crankshaft alignment, sounds like it's a tooth/notch or two off....
Old Jul 2, 2002 | 11:42 PM
XxR0myxX's Avatar
and if it is my main relay, how can i if this problem, do i need to buy anything, etc..??? thanks
Old Jul 4, 2002 | 04:56 PM
New User
the only place you can get a new main relay is the dealer. its just basicaly a big *** relay. If there was a problem with your o2 sensor, you would most likely throw a code. You try reading the ECU, see if any codes are stored?
[Modified by lshatchturbo, 5:59 PM 7/4/2002]
Hairy56
Apr 3, 2016 03:00 AM
tommy.
May 11, 2006 02:26 PM
Bobby808
Jun 22, 2005 03:16 PM
ashleeb
Aug 9, 2004 07:38 PM
boosted_zc
Mar 12, 2003 04:11 AM
