O2 sensor problem
Old Apr 2, 2016 | 03:17 PM
Hairy56's Avatar
Default O2 sensor problem
I have a 2002 Accord that gives an O2 sensor and O2 sensor heater circuit codes. The car has a new sensor and when I plugged in the scan tool there is no data for the sensor. I have tested the sensor to verify output and also did a continuity check on the wires going to the ECM/PCM. I hope someone out there has an idea cause the next step is an ECM but I don't want to do that if it isn't the problem.
Old Apr 2, 2016 | 04:06 PM
dh1212's Avatar
Default Re: O2 sensor problem
Check wiring integrity at the sensor from the ecm. Sounds to me like there is a break in the wiring.
Old Apr 2, 2016 | 04:20 PM
Hairy56's Avatar
I have already checked the wiring. I also checked the heater circuit and it is okay.
Old Apr 2, 2016 | 10:40 PM
MAD_MIKE's Avatar
MM Gruppe B
If you have backprobed the connections at the PCM and can read the O2S output, but the PCM is not registering it, then the next step would be to try a different PCM.
Of course you REALLY want to make sure it is the PCM before chucking out a few bucks for an unneeded PCM.
Old Apr 3, 2016 | 03:00 AM
Hairy56's Avatar
That's what I figured. Once I verified the O2 output and wire integrity it made sense that I was dealing with ECM problem. I wanted to be sure I hadn't missed something.
vtec2nv
Apr 12, 2013 04:52 AM
grndslm
Jul 5, 2012 05:11 PM
GsrIntegra789
Feb 9, 2009 06:01 PM
PH3593A
Oct 13, 2004 10:14 AM
1hotintegra
Sep 10, 2003 12:10 PM
