Blue smoke
Old Jul 15, 2004 | 08:39 AM
trev4's Avatar
Default Blue smoke
My prelude has been blowing blue smoke when the car heats up. I'm pretty sure that it is my piston rings that need replaced, but that's a lot of work. The way I figure it is, I have 3 options.
1. Just the the piston rings replaced
2. Get the engine rebuilt
3. get a new car
Any suggestions?
And does anyone know how much it would cost for the piston rings and/or to rebuild the engine?
Old Jul 15, 2004 | 05:43 PM
deSigi's Avatar
If it's smoking when it's idling, it will most likely be you valve stem seals. If it smokes when under load it'll most likely be the rings.
If the oil rings are finished, just changing them may not solve the problem. You'll need to get the cylinder bore measured to make sure it isn't out of round. If it is out of round and you only replace the ring, it'll smoke not long after.
If they are out of round, the best thing to do is to bore out the cylinders to manufacturer spec (.25mm), get +.25mm pistons and rings from Honda. Basically a rebuild.
Old Jul 15, 2004 | 06:23 PM
hondaguyef's Avatar
Default Re: (deSigi)
You supply parts and I'll rebuild it for cheap! I also know where there is an h23 longblock *rebuilt* for $400 lmk
trev4's Avatar
Thanks.
I'll probably end up doing an engine rebuild. Does anyone know how much rebuilding an engine costs?
Old Jul 15, 2004 | 06:32 PM
trev4's Avatar
Default Re: (hondaguyef)
I'm in PA, where are you?
DumpdEJ6
Apr 25, 2010 08:35 PM
alexb18c1
Dec 19, 2008 06:23 PM
ianp3k
Apr 24, 2008 12:05 PM
ck123
19
May 18, 2006 10:37 PM
tominos
22
Feb 18, 2003 08:55 PM
