Block help(want my car to run) help
AR AR sup DAWGS. I got a question. I am building a motor, the question is I sent my block to golden eagle and they accidentally O-Ringed my block. The head gasket I got is the Cometic High Perfe. Head Gasket and Golden Eagle said that it is not compatible with a block that has been o-ringed. Then I called Cometic and they said I can use the High Perf Head Gasket long as the rings are copper. I am confused and need expert advice from you H-Ter’s. Thanks.
[Modified by 1sloaccord, 6:10 PM 3/12/2003]
your block is o-ringed, so don't get a headgasket with o-rings on it. make sure that your headgasket does not have o-rings. personally i'll send it back to ge and make'em do it over again.
dantamparacer
Apr 17, 2012 07:37 PM
Prelude Vtec 23
May 15, 2003 08:12 AM
