Block Help
Old Aug 7, 2005 | 08:58 PM
testingcheck's Avatar
Default Block Help
I did a search and couldt find the right answer to this.
I know the main problem for a LS/VTEC build is the rods are weak to handle high-reving so replacing them with stronger rods (Eagle Rods) will help this, but is that the only problem?
Also what other things should I change inorder for this engine to be reliable and be able to handle high reving?
Old Aug 7, 2005 | 10:54 PM
sickerhatch's Avatar
Default Re: Block Help (testingcheck)
Actually the rods them selves aren't really all that weak.The rod bolts are the main problem.Also make sure all your bearing clearances are right on the money.
imanoobhaha
Jun 9, 2011 03:14 AM
VVENOM800TT
Feb 6, 2011 10:16 AM
redciv
Aug 30, 2002 10:32 PM
mntdewred
Jul 10, 2002 07:20 PM
