Black Vacuum Box
I found this black box under my intake manifold all cracked up. it seems to be a vacuum box and could have been the cause of my vacuum leek issue. basically wtf is it do i need it? Motor is a 94 GSR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 »</TD></TR><TR><TD CLASS="quote">ok so if i removed the IAB from my manifold and remove the box ill be fine?
depending on your mods; you will loose power in the low-mid range
Well ive already removed them from the manifold and the box is fuxord so what im asking basically can i just loop the vacuum lines and be ok? Im running two different ecu's a p30 + p28 since they both dont read IAB's
WHen removing the IABs from the manifold you will lose a few ponies under vtec. but running on a ps28 or p30 ecu you wont notice it. when you get in vtec the high rpm's 6000-8,500 pull alot harder its just like if you got a skunk 2 manifold
