Bizzare Brake Problem
Old Feb 8, 2004 | 08:29 AM
crxste's Avatar
Default Bizzare Brake Problem
I've just fitted my NSX calipers and 282mm rotors to my EG6, with Goodridge braided lines, hte brake system has been bled following the correct procedure in the manual.
However the brakes don't bite until the pedal is about 2" off the floor!
When they do bite they are superb
Any ideas what can be causing this?
Old Feb 8, 2004 | 02:09 PM
asmallsol's Avatar
Default Re: Bizzare Brake Problem (crxste)
what brake master cylinder are you using? I have read that since the NSX calipers are 2 piston calipers, it takes more pedal travel to "fill" the caliper and move the pistons.
Old Feb 8, 2004 | 04:41 PM
chameleon's Avatar
Default Re: Bizzare Brake Problem (asmallsol)
upgrade the master cyl and prop valve, those calipers are huge and are not meant for the puny master cyl and booster of a stock EG. if you have bled the system then you shouldnt have a problem other than upgrade whats neccesary.
Old Feb 8, 2004 | 05:05 PM
GreenBean's Avatar
Default Re: Bizzare Brake Problem (chameleon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">upgrade the master cyl and prop valve, those calipers are huge and are not meant for the puny master cyl and booster of a stock EG.</TD></TR></TABLE>
And also be sure there are no fluid leaks if you haven't allready....I'll bet your stops on a dime now
Old Feb 8, 2004 | 05:57 PM
Sliced Beard's Avatar
Default Re: Bizzare Brake Problem (GreenBean)
if i were you i would upgrade to a type r master cylinder
and brake booster
or if you really want some stopping power i would go with
a wilwood setup
Old Feb 9, 2004 | 12:26 AM
bayarea13's Avatar
first thing i would do would be bleed the system. then if the problem still exists think about a different size master cylinder
Old Feb 10, 2004 | 07:42 AM
crxste's Avatar
Default Re: Bizzare Brake Problem (NAPA182)
I have bled the system fully.
The master cylinder is the same one u get on the SiR II from Japan, so it;s not a small stock sized EG one like on a CX or summit
SigmaOmega
Sep 5, 2005 02:04 PM
ar5enal
Aug 9, 2003 12:43 AM
Tx92AccordExD
May 15, 2003 11:39 AM
bruvaman
Jul 9, 2002 07:19 PM
