Big puff of black smoke out of tailpipe
Old Mar 15, 2002 | 08:10 PM
3rdGteg's Avatar
Default Big puff of black smoke out of tailpipe
Everytime I smash out at WOT a big puff of black smoke comes out of my exhaust in-between my gearshifts. What does this mean and what could I do to fix that?
Could it be worn piston rings, etc?
Thanks ahead for the people taking the time to type up any inputs.
Old Mar 15, 2002 | 09:07 PM
Smashback's Avatar
Default Re: Big puff of black smoke out of tailpipe (3rdGteg)
Running rich....what have you done to the car?
Old Mar 15, 2002 | 09:50 PM
rainforest's Avatar
Default Re: Big puff of black smoke out of tailpipe (mplex2000)
could be rings prolly just rich though. unless there is hella smoke.
Old Mar 16, 2002 | 02:33 AM
88_SC_CRX_Si's Avatar
New User
Might have a look at your fuel pressure regulator. It may have started failing on you, causing it to run rich.
Old Mar 16, 2002 | 07:54 AM
flat-blk-HB's Avatar
also if your running with no cat or a test pipe it might cause that also...i konow mine did that in my car when i had a test pipe in place of my cat....
Old Mar 16, 2002 | 08:36 AM
mojoGSR92's Avatar
Default Re: Big puff of black smoke out of tailpipe (89EF-BCUMBIE)
Black smoke = running rich
White smoke = Burning coolant
-Bad, bad sign. Typically means blown head gasket or worse....broken coolant jacket. You would probably know if you had either of these because your engine would run fairly awful.
Blue smoke = Burning oil
-Generally worn valve guides, or piston rings
White "steam" = Vaporizing water in your exhaust
-Not a bad sign as long as this goes away after your car has been running for a while. Condensation naturally builds up in the exhaust piping, particularly if you only drive your car for short stints.
[Modified by mojoGSR92, 12:37 PM 3/16/2002]
Old Mar 16, 2002 | 10:10 AM
fixhondas's Avatar
its called normal operation- running rich at WOT is typical- since power is called for the ECU richens the mixture.
Old Mar 16, 2002 | 02:03 PM
ZUL8R's Avatar
Default Re: Big puff of black smoke out of tailpipe (fixhondas)
carbon buildup...
san_diego_DC
Sep 20, 2008 11:32 PM
Big red89
16
Oct 1, 2007 12:36 PM
john d ftw
Oct 9, 2006 11:36 AM
Fat Chick Magnet
Jul 8, 2006 02:31 PM
suckanut
10
May 14, 2005 04:10 PM
