big problem
Old Jul 11, 2003 | 10:25 AM
EtotheG's Avatar
Default big problem
aight i was workin on the motor last night when a friend was puttin the valve cover back on... when he broke one of the bolts... no we tried to drill it out.. didnt work... soo we plugged the hole and started it up... didnt leak oil ... so just wanted to know if its safe to drive around with for awhile untill i get it fixed...????
Old Jul 11, 2003 | 10:44 AM
mmuller's Avatar
Mad Scientist
Default Re: big problem (DumpedEG)
yeah it should be ok
Old Jul 11, 2003 | 10:46 AM
Kataku2K3's Avatar
Default Re: big problem (mmuller)
As long as it's not leaking it should be fine... Get a screw extractor, I'm sure you'll be able to get it out with one... Good Luck
Old Jul 11, 2003 | 12:10 PM
AzG35's Avatar
Uhm, if you are talking about the studs that come out of the valve cover that you put the nuts on, then those shouldn't be drilled out. They bolt into the cam caps. You can remove them with a 12mm socket.
TUR3Ovtec
Jun 19, 2010 08:23 AM
team714
Aug 19, 2007 09:00 AM
17GSR17
Nov 1, 2004 11:20 PM
ANB Clothing Co
Sep 2, 2002 11:41 AM
ringgold
Jul 8, 2001 11:56 AM
