Best Transmission fluid to use
Old Apr 17, 2003 | 10:14 AM
DavidTurbo's Avatar
Default Best Transmission fluid to use
What tranny fluid do you guys recomend? and how do I fill the tranny? I have a 95 LS tranny, an S80, I think. Thanks alot guys
Old Apr 17, 2003 | 10:15 AM
2point6's Avatar
Default Re: Best Transmission fluid to use (DavidTurbo)
Swepco ATF 20wt (yes, ATF)
Old Apr 17, 2003 | 10:17 AM
psi420's Avatar
Go to your HOnda dealer and buy tranny fluid.
I remove VSS and funnel fluid down through there.
Old Apr 21, 2003 | 05:52 AM
vadim's Avatar
Default Re: (psi420)
for hondas and acure you most!!!!!!!!!! use honda tranny fliud and only honda B/C the honda tranny fliud is different then others it has something in it only for honda the best way to fill it up is a funnel attached to tube so you can stick down into the hole and put 2qt in that should be good
ps the honda tranny fliud make tha tranny work the best. do not lot anyone tell you different.
Old Apr 21, 2003 | 07:23 AM
2point6's Avatar
Default Re: (vadim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vadim &raquo;</TD></TR><TR><TD CLASS="quote">for hondas and acure you most!!!!!!!!!! use honda tranny fliud and only honda B/C the honda tranny fliud is different then others it has something in it only for honda the best way to fill it up is a funnel attached to tube so you can stick down into the hole and put 2qt in that should be good
ps the honda tranny fliud make tha tranny work the best. do not lot anyone tell you different.</TD></TR></TABLE>
Honda MTF is good, but if you read a honda manual, some shop manuals suggest 10/30 motor oil as a replacement for honda MTF (it is not better ant the Factory stuff however), not to mention fluid capacities... 2 qts.... Check this one out before you listen to this guy. Honda MTF is great, but there are other options that work great. My experience is from the track and I swear by Swepco ATF. Many others in the ITR forum will also tell you that ATF works great as well.
Old Apr 21, 2003 | 08:56 AM
boostin b16's Avatar
Default Re: (2point6)
ROYAL PURPLE!!!! it by far out preforms any other MTF on the market!! atleast thats my experience.
royal purple!
Old Apr 21, 2003 | 09:59 AM
smokey2.0's Avatar
Default Re: (vadim)
i was told by my manager's brother, who is a honda tech for 15+ years that honda's mtf is symply 10-30 oil. and not waste my money on it, just to get regular 10-30 oil!
Old Apr 21, 2003 | 10:00 AM
smokey2.0's Avatar
Default Re: Best Transmission fluid to use (2point6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point6 &raquo;</TD></TR><TR><TD CLASS="quote">Swepco ATF 20wt (yes, ATF)</TD></TR></TABLE>
can you elavorate on your point, and where the hell can i buy this product. or at least read about it! thankx!
Old Apr 21, 2003 | 10:11 AM
psi420's Avatar
Default Re: (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">
i was told by my manager's brother, who is a honda tech for 15+ years that honda's mtf is symply 10-30 oil. and not waste my money on it, just to get regular 10-30 oil!</TD></TR></TABLE>
You know, I have heard the same exact thing.
Not sure what to do really.
I have also heard that Honda oil is simply Mobil 1.
Old Apr 21, 2003 | 01:26 PM
2point6's Avatar
Default Re: Best Transmission fluid to use (smokey2.0)
can you elavorate on your point, and where the hell can i buy this product. or at least read about it! thankx!</TD></TR></TABLE>
Typically, Swepco ATF (Southwestern Petroleum Company) uses more "shock absorbing" additives in its make-up. This can help under "High load" situations, such as "quick shifts" common in drag racing and road racing. The properties of the Swepco 20wt ATF are unique and this keeps the fluid from "pushing out" from between parts causing metal to metal situations. Regular oils can be compressed (to a point) and can be pushed out causing wear and damage. You can contact Dann Oebker at (520) 419-4242 about this product.
Old Apr 21, 2003 | 01:29 PM
John's Avatar
New User
Trust me, 10W-30 and Honda MTF are not the same. They look different, feel different, smell different, and I'd even go to be adventurous and say that they taste different. 10W-30 can be used as a temporary solution, but not a permenant one. Honda's MTF has some additional additives, what, I don't know...
Old Apr 21, 2003 | 01:40 PM
Hriday's Avatar
Amsoil 10w-30 motor oil, believe me it sounds weird, but my trans shifts way better than it did with honda trans fluid. Also keep in mind that you'll need to drive for about 500 miles before it really gets it's final "feel". The way they fill the trans is to but a manual pump which has hoses for in and out. Put the inlet in the fluid container and the outlet in the filling hole punmp fluid in untill it starts to come out. then put the plug back in and your done. I've also used a funnel with a long tube, that also works.
Old Apr 21, 2003 | 01:55 PM
dfoxengr's Avatar
mobil 10w30
Old Apr 21, 2003 | 01:57 PM
2point6's Avatar
Default Re: Best Transmission fluid to use (Hriday)
I ran Amsoil for a period of time but then shifting at high RPM's became difficult. I had to add the friction modifier. The tranny didn't last long as far as synchro wear either. The 2nd gear needle bearing failed (M2B4 Prelude tranny) due to improper lubrication.
Old Apr 21, 2003 | 03:36 PM
Lord Helmet's Avatar
Well I guess I better put my imput in: Redline MTL second choice honda mtf. capacity: 2 qts
Old Apr 21, 2003 | 05:13 PM
ChiBoy's Avatar
I'm going with Honda MTF. I just drained the tranny and the 10-30 that I took out was actually a little green. Either mold or copper oxide i guess. Niether one sounds good.
Old Apr 21, 2003 | 05:39 PM
91integraLSVTEC's Avatar
why use redline mtf? dat stuff is way to thick, 75w-90
Old Apr 21, 2003 | 06:27 PM
Default Re: (91integraLSVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91integraLSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">why use redline mtf? dat stuff is way to thick, 75w-90</TD></TR></TABLE>
you ever looked at redline mtl? probably not! it looks like red kool-aid and watery looking. so I don't know what you talking it's way too thick. from my personal experience even 20w50 oil looks thicker then redline mtl.
don't give misinformation when you don't know **** it.
Old Apr 21, 2003 | 07:37 PM
smokey2.0's Avatar
Typically, Swepco ATF (Southwestern Petroleum Company) uses more "shock absorbing" additives in its make-up. This can help under "High load" situations, such as "quick shifts" common in drag racing and road racing. The properties of the Swepco 20wt ATF are unique and this keeps the fluid from "pushing out" from between parts causing metal to metal situations. Regular oils can be compressed (to a point) and can be pushed out causing wear and damage. You can contact Dann Oebker at (520) 419-4242 about this product. </TD></TR></TABLE>
thankx for the info, what's the price per QT?
Old Apr 21, 2003 | 07:41 PM
Kamin's Avatar
good **** Scott, i never knew that..
havent seen you posting (anywhere, here or CR) for a while. been busy?
Old Apr 21, 2003 | 08:18 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: Best Transmission fluid to use (Kamin)
When I did my clutch/flywheel install all I had on hand was some Pennsoil tranny fluid. It absolutely sucked. I couldnt' get the car in first gear half the time and fast gear changes were met with a slight crunch. Drained it and put in Honda MTF and all the problems vanished.
For the guy that said its the same as regular 10W-30 I say take a wiff of both of them. My motor oil sure as heck doesn't smell like MTF. Besides the book only recommends it if you don't have any MTF avaible and suggests you change it out when you get the chance.
I can't remember but a long time ago someone posted up an article from Honda specifically about Honda MTF and why it works so well for our trannies.
Old Apr 21, 2003 | 11:55 PM
Stripped Honda's Avatar
99-0104
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi420 &raquo;</TD></TR><TR><TD CLASS="quote">
I have also heard that Honda oil is simply Mobil 1.</TD></TR></TABLE>
i know at norm reeves honda they use 10w30 in manual trannys not the honda stuf so i would never waste my money on that stuff .... and honda oil is mobil oil but not mobil 1
Old Apr 22, 2003 | 12:39 AM
MikeSarr_GSR's Avatar
Default Re: (Stripped Honda)
The honda MTF isnt that expensive. I change mine every 10K or so and I dont mind doing it. Much better than rebuilding synchros. $17bucks for 3quart. I put in 2.5 and that seems to be a good program for me every 10K with my wear pattern.
I like draining it and seeing it clear and free of material when it comes out.
Old Apr 22, 2003 | 05:30 AM
John's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda &raquo;</TD></TR><TR><TD CLASS="quote">
i know at norm reeves honda they use 10w30 in manual trannys not the honda stuf so i would never waste my money on that stuff </TD></TR></TABLE>
Remember that 10W30 is a temporary solution, but I wouldn't trust it for the long-term
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda &raquo;</TD></TR><TR><TD CLASS="quote">... and honda oil is mobil oil but not mobil 1</TD></TR></TABLE>
I'm pretty sure Honda oil is Castrol GTX.
Old Apr 22, 2003 | 05:34 AM
BabyDaddy's Avatar
Default Re: (MikeSarr_GSR)
Redline MTF
