bent valve, any other problems???.... please help!
first of all, this is the set up:
2000 gsr complete swap with 13k miles with-
b16a head new valve train etc
crower cams
inline pro cam gears
valve, springs etc. (purchased from jdmhondaparts.com)
skunk2 manifold
inline pro fuel rail
apex-i super vafc
chipped p28 ecu
mugen headgasket
walbro 255 fuel pump
jun flywheel and clutch
dohc del-sol radiator
b and m fuel pressure regulator
one night after installing the cams i took the car for a test drive and didnt have the cam gear bolts tight.. and boom i bent one of the valves on the head. I just wondering, what other harm could I of done to my engine by doing so?retainers, springs, head, ect is ok, right? I already did a visual check of it and everything esle seemed fine. please help me! I don't want to get any surprises.
crower cams
skunk2 manifold
apex-i super vafc
chipped p28 ecu
mugen headgasket
sorry for my ignorance, I just want to make sure that I'm doing things right. all I'd need to do is change the valve right? thanks Tech wizes out there.
You probably did only damage the valve. But check the piston for damage. Make sure you didn't dent it or anything. Or punch a hole in it...
valves open in pairs, and the pistons in two cylinders are at TDC at the same time, so you bent at least 4 valves. Most likely, you bent all eight.
You cannot look at the valves by eye, you have to measure to see if they still seat properly. If not, then you have to replace them and reseat them
i think so!
as i have just bent one valve recently, dont stress hte guy out.
you will need to pull your head to see, take it to a shop and they will be able to tell you, or you can DIY - but need proper tools...
t..
WONG FRIED RICE
Aug 24, 2006 01:34 PM
jr_istheman
Oct 28, 2002 09:24 AM
