Benen Fuel Rail Leak problem HELP!
Old Jul 3, 2010 | 02:02 PM
94cxhatch's Avatar
Icon2 Benen Fuel Rail Leak problem HELP!
ok i have a benen fuel rail and its been leaking out through the fitting/fuel line. i dont know what is causing this i was thinking it was the fitting size? if that is the problem then why would they even use that fitting? and i also read something about using a 6an fitting? im not too sure...can anyone help? need it fixed asap
btw i have a b series 94 hatch.
Thanks!
and heres my fuel rail
Old Jul 3, 2010 | 02:03 PM
kaiba's Avatar
Default Re: Benen Fuel Rail Leak problem HELP!
Is it leaking from the hose fitting or the thread?
Old Jul 3, 2010 | 02:06 PM
kaiba's Avatar
If thread. You can use something like this. Make sure it's usable on gasoline.
Old Jul 3, 2010 | 02:12 PM
94cxhatch's Avatar
im not too sure. i think it might be the thread. because i know there is a thin string thats inside the thread of the fuel rail right? and it came off
Old Jul 3, 2010 | 02:54 PM
94cxhatch's Avatar
i think it might be my injector O rings? anyone?
Old Jul 3, 2010 | 07:28 PM
94cxhatch's Avatar
bumppp
Old Jul 3, 2010 | 08:02 PM
uberEFtuner's Avatar
I had the same problem with an egay fuel rail. The threads were not getting tight. You need a new threaded adapter. I would email benin
Old Jul 3, 2010 | 08:23 PM
94cxhatch's Avatar
you sure?....can you give me some more info on that
Old Jul 4, 2010 | 05:59 PM
94cxhatch's Avatar
bump
Old Jul 5, 2010 | 12:39 PM
94cxhatch's Avatar
Originally Posted by 94cxhatch
bump
Old Jul 6, 2010 | 02:27 PM
94cxhatch's Avatar
Old Jul 7, 2010 | 02:44 PM
94cxhatch's Avatar
Old Jul 9, 2010 | 03:09 PM
94cxhatch's Avatar
anyone??
paintballer505
Welding / Fabrication
14
Sep 21, 2011 08:54 PM
killafred187
10
Aug 11, 2009 04:01 PM
rjardy
Oct 21, 2003 10:32 PM
Audipwr1
Jul 8, 2003 11:14 AM
