Which bearings for rebuild???
Old Feb 26, 2004 | 07:20 AM
Burke's Avatar
Banned
Default Which bearings for rebuild???
Hey guys. i'll be plopping in some new rods, pistons in my z6 next weekend and was wondering what bearings i should get and where i shold get them from. I hear stock bearings are great, but just wanted you all opinions?
Thanks
Burke
Old Feb 26, 2004 | 10:00 AM
LoSt is BlaCk's Avatar
Default Re: Which bearings for rebuild??? (Burke)
factory onda bearings if you have the money or a hook up, if not then i'd go acl. everybody has a different opinion though, i've been told that the acl's will kill my motor faster...but if your builder is good and has experience with them i see nothing wrong, by the way m motor with the acl's performs fine.
Old Feb 26, 2004 | 10:55 AM
carcala's Avatar
Default Re: Which bearings for rebuild??? (Chpt1onBOOST [DMV])
i recommend getting some ACL bearings. they are cheap and are good quality bearings. Alot of good builders use these bearings. Contact TOM at camp1320.com for the best prices!
Old Feb 26, 2004 | 11:06 AM
Rtype16's Avatar
Default Re: Which bearings for rebuild??? (carcala)
Stock Honda.
Old Feb 26, 2004 | 12:18 PM
Burke's Avatar
Banned
Default Re: Which bearings for rebuild??? (Rtype16)
how much should i expect to pay for some stock honda's???
Thanks
Burke
Old Feb 26, 2004 | 12:59 PM
Rtype16's Avatar
all depends I would suggest if you don't know someone at a dealer purchase them from hparts.com
Old Feb 26, 2004 | 03:58 PM
i have been quoted 8-12 bucks a half...a full set of acl's can be had for $100
Old Feb 26, 2004 | 07:15 PM
Kataku2K3's Avatar
I ONLY use OE Honda bearings... They may run a little more but I like them I get them from my friend that works at a dealership for ~$7.00 which is only $3.00 cheaper than they would normally be...
Old Feb 26, 2004 | 08:19 PM
N2O's Avatar
N2O
Default Re: Which bearings for rebuild??? (Kataku2K3)
We run stock honda bearings in our race motor. I will only run honda bearings and I never have a problem.
Old Feb 26, 2004 | 08:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">I ONLY use OE Honda bearings... They may run a little more but I like them I get them from my friend that works at a dealership for ~$7.00 which is only $3.00 cheaper than they would normally be...</TD></TR></TABLE>
is that price per half?
if you run honda, you should have nothing to worry about...that's the point...it's the acl's that most people have never had any experience with that are said to be "no good", is the assemblt is clean and correct both should do fine. i have and still run acl's with no problem as i said before...
Old Feb 26, 2004 | 08:54 PM
Kataku2K3's Avatar
Yea, that's per half...
Old Feb 26, 2004 | 09:18 PM
ExospeedAMcrx's Avatar
ACL bearings are not precise bearings. most of the bearings MAY fit, but not all the measurements will be exact. you have to consider that not all the clearances are exactly the same.
With Honda bearings, you can measure to match each bearing that you will need.
Old Feb 26, 2004 | 09:57 PM
K20EG's Avatar
Oe Honda Honda
Old Feb 27, 2004 | 06:57 AM
Burke's Avatar
Banned
Default Re: Which bearings for rebuild??? (K20EG)
thanks for the help guys. i emailed hparts for bearing and camp1320
do you guys have any other sites that might have them.
im new to this cause i wasnt expecting to have to do this, but i got ripped off on my motor and the bottom end wasnt built like it was said to
thanks again
Old Feb 28, 2004 | 11:18 PM
gambo117's Avatar
clevite? any opinions?
Old Feb 29, 2004 | 08:26 AM
Default Re: Which bearings for rebuild??? (gambo117)
my pops rocks clevites in his built 351 (ford v8) but i would not run them in my honda, those v8's tolerances are not nearly as close as a honda's...so even if there is a few differences in size, he will never even know.
Old Feb 29, 2004 | 10:24 AM
Honda OEM all the way. many non-Honda vehicles use Honda bearings.
golangti
Dec 20, 2007 10:02 AM
9seccivicsi
Jan 19, 2004 05:30 PM
boredracer408
Jan 3, 2004 08:20 PM
jdmR
Aug 12, 2002 11:00 AM
eddiecut
Jul 31, 2002 08:03 AM
