Bearing Clearances on Crank
Old Aug 6, 2003 | 05:22 AM
zCivic's Avatar
Default Bearing Clearances on Crank
I've got a B18A with ACL bearings. The bearings appear that there right at the svc limit of .0020 maybe just a hair under. I know alot of people have used ACL with no problems but seeing there at the svc limit would I be safe or should I get 1 size up from honda? Also this was measured in inches not mm. Just need some help and experience from others really. Opinions are also welcomed.
Modified by zCivic at 9:39 AM 8/6/2003
Old Aug 6, 2003 | 08:59 AM
IN VTEC's Avatar
Default Re: Bearing Clearances on Crank (zCivic)
What's your intended redline?
Old Aug 6, 2003 | 09:25 AM
zCivic's Avatar
Default Re: Bearing Clearances on Crank (IN VTEC)
Well its a LS/Vtec with GS-R crank girdle, so hope to get it to at least the 8200 stock red line for the PR3. Not 8200 all the time. Its just a daily drivin weekly drag motor. Not going to autox or anything....
Old Aug 6, 2003 | 09:55 AM
IN VTEC's Avatar
Not that I've had a lot of experience in experimenting with clearances, but I'd say you'd be fine with those clearances and running a step higher oil viscosity. Definitely wouldn't use 5W-30 on those clearances.
Personally, I prefer to run on the loose side of specified new clearances and I'm comfortable in telling you that those would be ok.
Old Aug 6, 2003 | 10:01 AM
zCivic's Avatar
ok I'm only at the limit on #1 and #5 main caps. The others are good. When I say at the limit I'm right at it not a hair over.
Modified by zCivic at 6:18 PM 8/6/2003
boostedefhatch
May 13, 2010 11:02 AM
acrocat
Jun 15, 2007 06:34 AM
W C L
Apr 17, 2005 12:31 AM
hondaeg8
Mar 22, 2005 12:50 AM
B16A1-EF9
Dec 16, 2002 09:06 PM
