Bearing caps
Old Apr 18, 2004 | 02:08 PM
SleepyHF's Avatar
Default Bearing caps
Ok, lets say I am under my car right now. I have the oil pan off and I am looking at the girdle and everything else. I unbolted the girdle but it is not loose. Also I took the bolts off the bearing caps, and they are not opening to expose the bearing. Why???
Old Apr 18, 2004 | 03:52 PM
torr's Avatar
Default Re: Bearing caps (SleepyHF)
alot of times the rod and main caps are stuck on pretty good even if the bolts are off. lets say that you have the bolts removed from the main/rod caps, take the butt of a hammer and hit the caps on each side. repeat each side until you can grab it off.
i hope i helped, because i didn't really understand your question.
Old Apr 18, 2004 | 06:53 PM
civickiller's Avatar
Default Re: Bearing caps (torr)
torr is right but when he says hit, he means either tap it with a rubber hammer or use a piece of wood, becuase you dont wanna tap it with your metal hammer
Old Apr 19, 2004 | 12:03 AM
SleepyHF's Avatar
Default Re: Bearing caps (civickiller)
schweet i used a rubber mallot, came right off. Thanks. Not not too sure if the bears are spun?? I look at them and only one is really really dark. The rest have scuff marks on them.
jarven093
Apr 27, 2007 08:21 PM
jsk62
Apr 26, 2006 11:35 AM
slofu
Aug 8, 2003 01:09 PM
One8Hatch
Dec 7, 2001 06:29 PM
