Battery relocation not working
Old May 2, 2015 | 11:19 AM
B20hatch15's Avatar
Default Battery relocation not working
Distribution block with power cable, msd ignition,starter, white cord from fuse box.
Breaker with 4g wire
Postive and negative hook ups.
Kind of a newbie still so some help would be appreciated thanks everybody.!!! Yes i know i have to mount the battery better dont mind that plz aha.
Old May 2, 2015 | 09:12 PM
Tyler Dirden's Avatar
I am Jack's...
Default Re: Battery relocation not working
The hardware looks legit, what are the problems?
Old May 2, 2015 | 09:18 PM
B20hatch15's Avatar
Like the power will cut out time to time and the battery dies real quick
Old May 2, 2015 | 09:20 PM
B20hatch15's Avatar
Am I supposed to be running a alternator cable straight from the alternator.?
Old May 3, 2015 | 04:57 AM
v4lu3s's Avatar
RTFM
Where is your ground?
Old May 3, 2015 | 06:43 AM
B20hatch15's Avatar
The ground is fine its screwed into where the tire was mounted but ill be moving it soon because i will be putting the battery on the side
Old May 3, 2015 | 04:59 PM
v4lu3s's Avatar
RTFM
the most common problem i have seen in battery relocations is a bad ground. usually too much paint or corrosion on the connection.
civicron
Honda Civic (2001 - 2005)
Aug 5, 2016 05:56 AM
CoCoChanel
Jan 15, 2015 11:03 AM
logeywartooth
Sep 14, 2008 07:10 PM
blackdelslo
Jun 5, 2006 03:15 PM
Steemo
Sep 9, 2004 10:57 PM
