Battery light and voltage question...
Old May 11, 2007 | 06:01 AM
80884's Avatar
Default Battery light and voltage question...
00 civic, does the battery light turn on when the voltage in the charging system drops to a certian level? If so what voltage does the light come on?
I'm trying to diagnose a lack of fuel problem that I experienced on the dyno. The tuner is trying to tell me I had a voltage drop that caused the pump to not pump enough fuel. My question is if I never had a battery light on what is the lowest the voltage could have gone? After I shut the car off, did a compression test I check the battery and it read 12.1V.
Is it possible that the pump somehow didn't get enough voltage and I got no battery light? A1000 fuel pump.
By the way the car was at 70% fuel at 8000rpm with the A1000, 1000cc injectors and no boost!
Old May 14, 2007 | 03:36 PM
80884's Avatar
Default Re: Battery light and voltage question... (80884)
anyone?
Old May 14, 2007 | 05:09 PM
EE_Chris's Avatar
Did you do any re-wiring for the A1000?
Old May 16, 2007 | 08:53 AM
80884's Avatar
Default Re: Battery light and voltage question... (EE_Chris)
yes, wired it per the instructions. The only factory wiring used was the signal wire to the relay.
siVix
Aug 3, 2011 06:28 PM
