battery fuse keeps blowing
Old Dec 28, 2008 | 08:22 PM
lina sok's Avatar
Default battery fuse keeps blowing
cant figure it out and i'm very stumped! i searched all honda tech and had no answers so i was wondering if anyone had this type of problem before. all i did was took my motor out and swapped a gsr trans to a b16 trans. then when i finished putting everything back together the car started but was missing. then i shut if off and started it again then the fuse blew. another thing is i relocated my battery over a year ago and never had any problems but i have a 80 amp fuse there. but back to the problem right when im cranking the motor over after about 6 cranks the fuse will blow. so i looked to see if anything was touching like the starter power and switch and nothing. and it still did it so i took out the engine harness and checked it for burnt wires and any sort of issue and no problems there. so if anyone has and help to offer please help
Old Dec 28, 2008 | 09:07 PM
dtapia's Avatar
Default Re: battery fuse keeps blowing
their is a direct short to ground check the starter cable and make sure its not grounding on the starter body,if thats ok time to start looking at other wire issues.
Old Dec 29, 2008 | 04:41 AM
fcm's Avatar
fcm
Old Fart
If it happens only when cranking to start the problem has to be the starter or starter solenoid or load when starting exceeds 80A.
So I understand... you are talking about a fuse you have in the power lead running from your relocated batt. to the starter motor, is that correct?
If so, what gauge is that power lead and what type of fuse are you using?
Have you checked to see what the load is on that power lead with everything off? 94
Old Dec 29, 2008 | 08:27 AM
Stephanie123's Avatar
I swapped starters thinking it was the starter butthe same thing happens. Also I've been jumping from 50,80 and 100 amp fuses and they all blow. I'm assuming its not a short in my engne bay harness cuz wouldnt one of my interior fuses blown but I located another engine harness and I'm gonna swap that to see. But if u got any ideas keep them comming
Old Dec 29, 2008 | 08:31 AM
I ya for the gauge ENT remember but I'm gonna say its 4 gauge think there could be a short in a power lead I'll try that too
Old Jan 4, 2009 | 04:11 PM
premiumlude's Avatar
plz, any issu???????????
i do the same thing,
the battery in the trunk
a engine swap
the car runing for a day, and now, each time i crank the engine, the battery fuse blow!?!?!?!
plz, help me
Old Jan 5, 2009 | 04:43 AM
fcm's Avatar
fcm
Old Fart
a engine swap
plz, help me
Same question lina sok has yet to answer, are you talking about the fuse in the power cable from the batt. to the starter motor?
What gauge is the cable?
What amperage is the fuse?
What type of fuse is it? 94
Old Jan 5, 2009 | 05:37 AM
gauge 4
100amp
battery fuse
Old Jan 5, 2009 | 08:46 AM
dont know why, but the fuse stop to burn.
now, the engine crank, but dont start, only some random explosion.
tomorow, i go to the tuning shop
i have alot of stuff under the hood, need expert not a dealer macanic who change the piece by the same # of piece
i unplug the 6a msd, change the 1200cc injector for the stock one and put on the oem ecu
still dont start
Old Jan 5, 2009 | 11:17 AM
fcm's Avatar
fcm
Old Fart
First the fuse should be replaced with a 150A, current capacity of 4ga power cable is 150A.
Do you have 12V+ on the black/yellow lead going to the distributor assembly when ign. switch is in run and start?
Do you have 12V+ at the injectors when ign. switch is in run and start, [the lead that is the same color on all injectors is the 12V+ lead].
Can you hear the fuel pump prime when ign. switch is turned to run? 94
Old Jan 5, 2009 | 12:51 PM
i fixed the problem today (by -20degres!!!!! damn quebec)
i unplug the msd 6a and coil blaster
i change the 4 spark plug
i change the msd spark plug wire for the oem
not sure where was the problem, but i fit it
tomorow, tuning time
thx for your help
Old Jan 5, 2009 | 04:23 PM
fcm's Avatar
fcm
Old Fart
"damn quebec"???
Your going to have the language police on your ***, I am pretty sure that should be "damner Quebec" or "crisse Quebec". 94
PS, I had issues with the lead from my MSD cap to the Blaster coil also, the lead would not fit properly into the cap, and it was from a $150 Sparco set, replace it, and spark plug leads, with a good set of MSD leads and have not had a problem since.
lina sok
Jun 25, 2009 01:06 PM
lina sok
Dec 31, 2008 12:51 PM
karatekid1981
May 18, 2007 09:21 PM
crxpwr1
12
Mar 12, 2007 12:12 PM
95civicSirCoupe
Sep 10, 2006 04:02 AM
