Basic Head Porting Walkthru....
Old Feb 5, 2003 | 02:43 PM
  #26
XLR8 GS-R's Avatar
Default Re: Basic Head Porting Walkthru.... (tzsir)
...and yet STILL nobody answered my question on FI setups. Any Help?
Old Feb 5, 2003 | 03:12 PM
  #27
HEAD's Avatar
Default Re: Basic Head Porting Walkthru.... (spoonedcivicG4)
you can expect to pay some where between $650-1000 depending on degrees of porting, and then you have to decide if you want aftermarket valves and other hard parts which is when it starts to get pricey!
Old Feb 6, 2003 | 08:36 PM
  #28
MAX_CFM's Avatar
Default Re: Basic Head Porting Walkthru.... (HEAD)
hay head u got any pix of yur work
Old Feb 7, 2003 | 10:30 AM
  #29
HEAD's Avatar
Default Re: Basic Head Porting Walkthru.... (MAX_CFM)
I have pics of some domestic stuff i have done . I am going to try to get some pics of the sport compact stuff maybe this weekend. what kind of head are you looking for I have everything in I think except for a Type R head.
Old Feb 7, 2003 | 10:34 AM
  #30
GZERO's Avatar
Default Re: Basic Head Porting Walkthru.... (XLR8 GS-R)
porting a turbo head will make it flow better, but the real difference doesn't come in till high Boost levels. At least that's what i heard and read about.
P&P a turbo engine it's a plus, but it has to be done for turbo. Meaning have the head P&P for turbo aplication.
Old Feb 7, 2003 | 11:49 AM
  #31
XLR8 GS-R's Avatar
Default Re: Basic Head Porting Walkthru.... (GZERO)
Thanks GZERO- at least someone herd me!
Ken
Old Feb 7, 2003 | 01:42 PM
  #32
GZERO's Avatar
Ken
anytime
Old Feb 7, 2003 | 01:51 PM
  #33
evolve's Avatar
Default Re: Basic Head Porting Walkthru.... (BudaKai)
Laminar flow is the way the air flows away from the walls by creating a slightly rough surface to keep the bulk of the air away from the walls so fuel doesn't collect on them. Polishing causes the fuel to collect no matter if it's NA or FI. It's just plain Fluid Dynamics. Polishing is good on the combustion chamber's in the head, and on the piston to reflect heat back into the chamber instead of heating the water jacket. To further the effect squirt some water or alcohol to clean the cylinders before every run if you're that much of a stickler to get as much as you possible can.
The rough areas help to create certain boundry layer design flow, which changes laminar flow. The boundry layer flow design is dependent on turbulence of the "rough" areas, and surface friction. Laminar flow in itself doesn't prevent collection, its merely the cause.
Old Feb 7, 2003 | 07:50 PM
  #34
HEAD's Avatar
I need help! how to post a pic ?
Old Feb 7, 2003 | 08:14 PM
  #35
MAX_CFM's Avatar
e-mail me dude I have a bizz that does head work I worked in Winston cup 8 yrs porting heads and 6 in dragracing before that now in doing imports go figure
well making good money thou
Old Feb 7, 2003 | 08:27 PM
  #36
HEAD's Avatar
I have friends in cup and I used to work for Pat Musi for a few years-went to school at SAM in houston tx
Old Feb 7, 2003 | 09:35 PM
  #37
GZERO's Avatar
From Head:
msx-cfm wanted to see his head porting , this are from a chevy big block
this is for "Head"
Old Feb 7, 2003 | 09:39 PM
  #38
HEAD's Avatar
Thanks for the help I'll figure it out one day
Old Feb 7, 2003 | 11:06 PM
  #39
MAX_CFM's Avatar
Nice work dude
Old Feb 8, 2003 | 12:36 AM
  #40
fu*kfaceC1EH2's Avatar
Default Re: Basic Head Porting Walkthru.... (BurlyHatch)
Old Feb 9, 2003 | 12:04 AM
  #41
lazerus's Avatar
i'd imagine if your injector setup was good enough, that the fuel injectors sprayed fuel directly ontop of the intake valves, that you would still get good atomization, because along with the rough finish of castings, you also have "swirl" that is designed into the head.... it really depends on your fuel setup... if your fuel injectors are spraying it directly on to the sidewall of the intake port.... if you're really getting down to the nitty gritty, you may want to re-design the way you have things set up.
Old Feb 9, 2003 | 09:18 AM
  #42
HEAD's Avatar
Default Re: Basic Head Porting Walkthru.... (jerseykid609)
thanks for the kind words guys, if you guys want I can post some pics of import stuff tommorrow. I bet nobody thought they would ever see a chevy head in honda tech!
85mmek9
Jan 20, 2007 03:19 PM
dayaftertomorrow
21
Mar 7, 2006 11:39 AM
XLR8 GS-R
Apr 23, 2004 06:05 PM
BurlyHatch
Jan 29, 2003 10:12 PM
canuck-mx6
Dec 8, 2001 10:36 PM
