balanced and blueprinted....
Old Sep 1, 2002 | 11:49 AM
DC2 12's Avatar
Default balanced and blueprinted....
hey what exactly does balanced and blueprinted mean.. thanks
Old Sep 1, 2002 | 01:06 PM
sgT's Avatar
sgT
Default Re: balanced and blueprinted.... (hoacun)
it means to balance all the parts in the motor and put everything within factory specifications.
Old Sep 1, 2002 | 04:20 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: balanced and blueprinted.... (sgT)
blueprinting is a little bit more than putting things within the factory specs. it means putting everything within each related parts specs. such as, piston to cylinder clearance, make them all one number, prefferably the most desirable one. very expensive, as you might have to purchase multiple copies of parts.
stan
Old Sep 1, 2002 | 04:41 PM
_BEN_'s Avatar
I kinda have an add on question about balancing.
So how will this affect the crank if you were to upgrade to a set of light weight rods and pistions.
Even so if they were all matched wouldint the counter balanced weights on the crankshaft be too much for the new lighter stuff?
Or are the counter weights on the crankshaft just there for balancing the crankshaft itself?
raverx3m
Jan 15, 2015 06:10 PM
Johnny_9
69
Mar 10, 2011 03:09 PM
navz121
Nov 18, 2006 06:50 PM
civickiller
Mar 18, 2004 06:34 AM
VtecDA9
Jan 5, 2003 01:19 PM
